How do i stop........
My passenger front wheel from rubbing the inner arch when i go to almost full lock.
It's not just rubbing slightly, it's torn the plastic and the paint from the bodywork behind. Any way i can stop this? Tried 4mm spacers but it still done it. Any further and my wheels will be sticking out of the arches
the rack prob aint central.
if it is, then its prob the wrong rack (as FRST had its own rack)
or the wheels are to blaim.
i had it years ago and it was cos i got given the wrong rack when i replaced it
xr2i ones are same as other fiestas, its only frst that has different rack as its a quick rack and has a lock to lock of 3.75, where as the xr2i etc has a 4.25 lock to lock, thats another halh a turn
the problem is you running 195/50/15s you need a 45 profile, the rack makes no differance altho the frst rack is a different ratio the car still has the same turning circle
you can get limiters for the rack, or used to be able to.
your problem if its not the rack etc, will be due to wheel size, if you have 6.5x15's your ok, if you got 7x15's it will rub, but off set comes into this as well.
to check the lock to lock, turn it full lock 1 way, say to the right, then count the numberof full turns the steering wheel makes plus any 1/2's or 1/4's and that will tell you what lock to lock you got, from there you can work out what ya got.
Originally Posted by Phil DJ
I'll check the width of the wheels then. Am i right in saying that et35 offset is probably the wrong offset aswell?
Im runnig 7x15" Alloys with 45 profiles and i get VERY slight rubbing on full lock - this is with an offset of ET35. The alloys are ET40, but they rubbed badly on the shocks so im using 5mm spacers.
HTH
Im ordering a set of 6.5x15 ET37 alloys soon - wil be interested to see if they rub or not - i doubt they will with an extra 2mill of clearance and half and inch less width.
the the higher the number e.g et40 the closer to the shock the wheel is, or another way of looking at it, the further away the center is.
that about right?
that about right?
sweet, i got some mondeo rims to go on my fez that are ET40, i got coil overs so thats not a prob, well fronts "might" need a small spacer to clear the ARB drop link bolt as the 15s touched it, well did untill i file 4 mm off the end of it
yeah thats good, cheers for that mate, hopefully the rear will be ok now as with the rear disc conversion it pushed the wheel out about 20mm and the wheel started to catch the arch a bit
Originally Posted by AGAR-COSWORTH
jayRS - correct - hence why ET40 rims caught on the inside against the shock, then with 5mm spacers (making them ET35 offset) they didn't rub - ie further away from the suspension.
But mine are ET35 and they rub like fook on full lock???
I don't know. They don't look as wide as escos rims. Maybe i measured them wrong or something.
I know the guy i bought them off had them on a MK3 Escort Cabriolet and he had no problems
Ok, i took a wheel off and behind it was stamped "7.0xJ15" which is weird coz it's definately 8" wide
Double checked on my standard wheels and it's got "5.5xJ13" and i measured that at 5.5" wide
So is the stamp on my 15" wheel wrong then?
na prob not, did you allow for the tyre?
thers ya problem mate, 7 inch wide, same as me, and same problem.
all ya can really do is make sure the rack is central and when the tracking done there isnt loads of adjustment on that side.
oh and hope for the best
it is a tiny bit possable that a small wheel space will help it (not stop it, and fit 1 to each side)
The wheel is the same width as the tyre. Took the wheel off and measured from the inner rim to the outer rim. 8".
Sold them to my bro now anyway. He has my old XR2 and they fit on there no probs
Didn't work. Standard rims back on. Think i'll save up for some Mondeo 16's now
