what turbo to run ???
Old Aug 9, 2006 | 01:31 PM
iamrab's Avatar
iamrab
Default what turbo to run ???
hello lads
im thinkng of getting a turbo for my rst but dont no what to get , the spec soo far
mongoose 3" bore exhaust
superchip
standard airbox
kent cvh35 cam and pully
proalloy front mounted intercooler
im only running 12psi at the min cos the cars not set up yet (its going in 2weeks to get this done) but what turbo should i get ...was thinking mybe a t3 stage 2 but they are expensive what about getting a cossie turbo ..which one do i use? and what do u reckon ......in the future im gonna do the head ,rods and pistons ..so mybe a turbo to do this as well ...or mybe not cos i migten get around to do this .....
Old Aug 9, 2006 | 03:10 PM
Noisy Boy's Avatar
Noisy Boy
Depends on what you go, i would stick with the T3 for the quicker reponse unlike the bigger turbos but like i said mate its down to what sort of drive your after?
Old Aug 9, 2006 | 03:47 PM
Badman38's Avatar
Badman38
Default Re: what turbo to run ???
Originally Posted by iamrab
hello lads
superchip
standard airbox
4x4 cossie turbo would work with alot of Variations, but depends on what sort of power you are after then spec the turbo for that power.
Old Aug 9, 2006 | 06:36 PM
iamrab's Avatar
iamrab
i dont mind a bit of lag as the cars not a daily driver, i want a turbo charger thats not gonna cost the earth and its a spool up ....ive found that a lot of people go with the 4x4 cosworth turbo from a saff, whats the difference ?
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
turbobill
Aug 9, 2015 05:21 PM
