Low compression plate / pistons
whats cheaper?
was reading a old fast ford mag, chap was running a zvh with standard bottom end with a low compression plate, 2 felpro head gaskets, 218bhp @ 8psi
multiple headgaskets blow , plates melt and move
im using Mitsubishi Tredia Turbo 1800 pistons 80.6mm , shit cr of 6:1 but i could boost to 2 bar with 102.7 octane
i made 150kw atw at 1.5bar
donkey sub 3k , monster above this with a t34 and modified cvh 22 cam
I was running a a decomp plate on my standard RST engine without any problems at all. Had to use it as head had been skimmed too much. You wellseal the plate to the block and then use a standard head gasket on top of that. I also put wellseal on both sides of the head gasket with every engine I build. I got mine from http://www.ferriday.co.uk/ did the job superb.
I was running 18psi of boost without any problems for a year. Only stopped using the engine after oil pressure had dropped and found it had a worn crank.
Originally Posted by RST Ski
whats cheaper?
i know of a 1.6 cvh which makes 256 bhp at 13 psi and revs to 7k
that zvh most likely made its 218 bhp at 5000 rpm peak
