Fiesta Zetec-S - Throttle bodies.... 11JUN07 - PAGE 5.update
Old Aug 7, 2006 | 09:53 PM
OldDan's Avatar
OldDan
Default Fiesta Zetec-S - Throttle bodies.... 11JUN07 - PAGE 5.update
Due to Ford Fair this weekend, I have now caught the track bug... Although I only had 20 minutes, it was very good fun..I found out a few things though..
Staying off the gas, even when not going fast, can still send you a little sideways, but luckily I caught this..
And, my car doesn't like being hammered for 20minutes, because the temp starts to rise.. Wiring in a switch for the fan this weekend, hopefully to stop this happening again..
Check the expression on my face..
Right, here are a few photos, explaining, what has been done, and what needs to be done.. It won't interest anyone, as it's not a massive project, but it's a bit of a learning curve for myself..
I plan to do as much as I can by myself, and with the help of friends, cutting cost, and I suppose I'll feel a hell of a lot more proud once it's done, knowing I've spent lots of time on it.
This is where the car lives..
Room isn't too much of an issue, as the Bike can be removed, and then there is pretty much as much room as you'd like..
Stripped
I've already stripped the car, all the plastic that can be removed has been, as well as pretty much everything else, except the rear wiper motor.....
Spare wheel removed...
Sound deadening is next to come off, but I'm putting it off, as I've been told how much of a pain in the arse job it actually is...
The interior is all over my bedroom/garage... My mother loves it..
What I'll be needing is a cage.. don't really want something mental, just a rear cage, and possibly to the front of the car, but no doorbars, as I want to use the car as an everyday road car as well..
Something like this possibly? Anyone got any links as to where I can get one?
These should be being replaced with...
Corbeau Sprints.. They're Kevlar/GPR composite so should hopefully but lightish.
Oh, and the extra wide version please...
And that ^^ needs replacing with something a little more grippy..
Suspension
Suspension is pretty much sorted.. AVO coilovers, front upper and lower OMP strutbraces, so it handles very well already..
But this needs sorting... and should be sorted within a few weeks..
Yep, another popped avo.
Tyres, Brakes etc.
Brakes are sorted too, I've got some 300mm ST170 discs, with Jaguar X Type / Mk3 Mondeo calipers.. They stop very well, but I think some propper pads are in need, any suggestions on this? as well as decent brake fluid...
Also got some grippy Toyo Proxes T1-S's on.. which will do for now, as I got a decent deal on them..
Powerflex bushes are needed too..
Engine?
Not too concerned about the engine just yet, it's nippy, but brakes and suspension are the main things first..
For now though I have a 4-2-1 with a decat which helps it breath a little more, and pops and bangs like mad...
That's all I can really think of at the moment, obviously I'll update as often as possible.. and if I've missed anything let me know?
Sorry if it's been a long read! Thanks for reading..
File Type: jpg
Old Aug 8, 2006 | 12:02 AM
GazzaG's Avatar
GazzaG
Nice one dan,
looking good on the track there.
What sort of wheel you after?
Old Aug 8, 2006 | 01:37 AM
89xr2's Avatar
89xr2
Brap!
Cool project. Looked at buying one of these myself.
The only steering wheel i'd recommend is this one.
http://www.demon-tweeks.co.uk/produc...=SSW015R383PSN
you wont find a nicer wheel
Also what size wheels are they? they look like 17's. If they are you'll probably find it handles better on the original wheels
Old Aug 8, 2006 | 02:37 AM
r-s-turbo's Avatar
r-s-turbo
Default Re: Fiesta Zetec-S - Track day prep/fun!
LOL its called lift-off oversteer! its so fun! its how i wrote my blue zetec s off into a bridge back in march-ish!..o well my s2 cushioned the blow
Old Aug 8, 2006 | 07:11 AM
OldDan's Avatar
OldDan
17s...
The problem is I can't fit 15s over the brakes, so need to find some 16s.. not in that much of a hurry for those yet though..
Cheers.
Old Aug 8, 2006 | 09:02 AM
Mr Shannon's Avatar
Mr Shannon
About time you got your hand dirty too you big tart
Old Aug 8, 2006 | 11:34 AM
rich_frst's Avatar
rich_frst
nice project dan, like it mate...
Old Aug 8, 2006 | 01:57 PM
Sally's Avatar
Sally
Nice one Dan
I didnt see you round the track at FF
Old Aug 8, 2006 | 05:23 PM
OldDan's Avatar
OldDan
Thanks so far
Buying some seats tonight, unfortunatly demon tweeks don't have the Corbeau sprints in stock, and as I really want to be getting on with this, I'm going to look around for some others, or see if I can purchase the seats from anywhere else...
Old Aug 8, 2006 | 07:30 PM
heeman10's Avatar
heeman10
Ello Sorry I never had the chance to stop and chat etc at the show! Looks like those 20 minutes have changed your life/car (same thing )! I would suggest buying grooved discs or having yours grooved, it makes an enormous difference in my experience. I swapped from XR2i calipers and grooved 249mm discs to Wilwood 4 pots and 285mm smooth discs, and the jump in performance should've been much much bigger. The discs are extremely glazed, as are the pads, and I'm sure it's down to the smooth surface rather than the grooved face that helps keep things that bit rougher. Rally Design refused to groove them for me at the time of buying, but I'm looking to get someone to do them for me before too long, I know they'll sharpen up.
Old Aug 8, 2006 | 08:08 PM
Ed_ZetecS's Avatar
Ed_ZetecS
Thanks so far
Try Kev @ Powartek... http://www.powartek.com/
He did me a BLINDING deal on a Corbeau Revolution and mounting frames
Old Aug 8, 2006 | 11:01 PM
OldDan's Avatar
OldDan
Right,
Just bought 2 of these, should be here in the next few days...
As you can see they're Kevlar, so weigh 7.5kg.. so should be light enough!
Old Aug 9, 2006 | 12:08 AM
Mr Shannon's Avatar
Mr Shannon
Loving the seats mate where did you order from in the end?
All you need to do now is get your ass on a diet son
Old Aug 9, 2006 | 06:30 AM
OldDan's Avatar
OldDan
No I don't..
Bought the "excel" version..
Got them from Performance Centre in the end,
Old Aug 9, 2006 | 07:42 AM
Mr Shannon's Avatar
Mr Shannon
Good effort bud
If you need to get lap times down by shedding some weight i'll glady take it round
Old Aug 9, 2006 | 08:38 PM
OldDan's Avatar
OldDan
Right, I cancelled the order, as I found out these will be fixed to the floor....
and I wanted a little bit of movability..
and then I thought.....
FUCK IT They're on their way.. in grey, with silver sidemounts..
Old Aug 9, 2006 | 09:15 PM
coombsie66's Avatar
coombsie66
Lightly grooved discs would reduce the glazing, but so would a higher heat rating pad, the grooves would also increase the wear rate of the pad. But from the motorsport discs ive seen glazing (as long as it is distributed around the disc evenly) is no bad thing, you'll always get pick-up when the pad reaches high opperating temps. Its cracks in the disc that are a problem! And 'cutting' grooves (unless radiused shallow channels) will increase the disc's suscepability to cracking with heat cycles.
Old Aug 10, 2006 | 11:06 AM
heeman10's Avatar
heeman10
Yep, grooves do reduce brake pad life, but I'd rather that than have two smooth shiny surfaces to press together when I'm trying to induce a braking friction. I'm quite sure the pads I have on the Wilwoods now are the same pads I had in the XR2i calipers when I had the 8 groove Tar.Ox discs on, so it's a fairly direct comparison; 285mm 4 pots compared to 249mm standard 2i items.
Old Aug 10, 2006 | 11:11 AM
Mr Shannon's Avatar
Mr Shannon
Tar.Ox is just down the road from my office and they will groove your disc's for a price.
Dan dont worry about the seats, PMT are on to it
Old Aug 10, 2006 | 11:12 AM
OldDan's Avatar
OldDan
Good stuff.
3 weeks they'll be here though...
Old Aug 10, 2006 | 11:16 AM
Mr Shannon's Avatar
Mr Shannon
3 weeks
Whats the reasoning behind that?
Get your dash flocked dan, you know it makes sence
Old Aug 10, 2006 | 11:19 AM
OldDan's Avatar
OldDan
3 weeks
Corbeau are shut for a week, and they're made to order....
So they said End of Aug.
Gay really, but should be worth it.. don't know where does flocking ?
Old Aug 10, 2006 | 11:22 AM
heeman10's Avatar
heeman10
That means they can't be too far from me! Cheers buddy
Old Aug 10, 2006 | 11:23 AM
Mr Shannon's Avatar
Mr Shannon
The flockers
Ask neil, he's getting a few things done IIRC
Old Aug 10, 2006 | 11:24 AM
Mr Shannon's Avatar
Mr Shannon
Carrs industrial estate in Haslingden jimmy
Old Aug 10, 2006 | 11:42 AM
heeman10's Avatar
heeman10
Righty ho, duly noted
Old Aug 10, 2006 | 11:47 AM
89xr2's Avatar
89xr2
Brap!
[quote="YoungDan"]
Garage 19 on here did fugeass' dash and the FF stuff.
Suffolk Flocking services Heard really good things and good prices
Central blast cleaning - Heard amazing things. bit more expensive though.
Old Aug 10, 2006 | 12:02 PM
OldDan's Avatar
OldDan
[quote="89XR2"]
Is it a few days process? Probably one of the last things I'll do.. seats, suspension, rear strut brace and cage are the most important things at the moment I think!
Old Aug 10, 2006 | 12:06 PM
89xr2's Avatar
89xr2
Brap!
I think a week turnaround is pretty normal. TBH
You tried safety devices for a cage? Pretty sure it would be easy to get a cage for your car due to all the fiesta's they race.
Get that sparco wheel i posted up as well
Old Aug 10, 2006 | 12:17 PM
Mr Shannon's Avatar
Mr Shannon
[quote="YoungDan"]
The order your doing it in at the minute is spot on mate, flocking wouldnt be top of my list but it would deffintley be in there at some stage
Old Aug 10, 2006 | 12:20 PM
89xr2's Avatar
89xr2
Brap!
Oh forgot to say, you'll probably need the dash out to do the cage anyway so just get it flocked then
Old Aug 10, 2006 | 12:22 PM
OldDan's Avatar
OldDan
I will do, not just yet though, see what funds are like end of the month
Also, what about a horn?
Get the basics sorted first, then we'll go from there
Also I think these adjustable camber/caster wishbones need ordering from Brom@Zoo... I'm in need of a nearside wishbone, so I might as well get both..
Old Aug 10, 2006 | 12:23 PM
Mr Shannon's Avatar
Mr Shannon
How much they going to set you back dan?
Thinking of spending a small fortune on some handling goodie's for mine once its setup etc
Old Aug 10, 2006 | 12:26 PM
OldDan's Avatar
OldDan
According to the post in traders bit they're Ł365 a pair..
But he does some that are just camber adjustable for Ł320..
Old Aug 10, 2006 | 12:30 PM
kaplaybunny's Avatar
kaplaybunny
very nice dan
Old Aug 10, 2006 | 12:32 PM
OldDan's Avatar
OldDan
Originally Posted by kaplaybunny
very nice dan
Thanks!
Another track photo from Sunday.
Old Aug 10, 2006 | 12:49 PM
Mr Shannon's Avatar
Mr Shannon
You still going to keep it as your everyday car or make it into a proper track weapon?
Old Aug 10, 2006 | 12:52 PM
OldDan's Avatar
OldDan
Not sure yet,
I wanna be able to use it on the road, for some fun every so often, but might buy a second car and use that for work...
Think I could insure a car and buy one for under 400? lol
Old Aug 10, 2006 | 01:01 PM
Mr Shannon's Avatar
Mr Shannon
Erm at your age... no
Old Aug 10, 2006 | 03:29 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
These fiesta's can go really well
#13 (Think that's his user?) off here race's them i think? PM him mate
Cool little project
