Split turbo oil return pipe
Just dumped all the engine oil all over my drive (missus is well hacked off), found big split in rubber turbo oil return pipe, anyone know where I can get another one from. Ford want £32.00 + VAT, there must be a cheaper option???
Had to get one myself mate when I did my T3 conversion on my Fiesta. I was recomended all sorts of tricks but most looked like crap and some just simply didn't work. I opted for the Ford pipe in the end
What you need to do is find a 45 degree silicon pipe, 19mm internal diameter and it HAS to be flurol lined, because oil eats up normal silicon hoses, the flurol lined ones are specifically for oil applications.
That will also be making your car run like poo as its an air leak
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
