Pipe to the ECU from Manifold
Old Aug 5, 2006 | 09:49 PM
davidnormanuk's Avatar
davidnormanuk
Default Pipe to the ECU from Manifold
On the original pipe for the RST there is a restrictor in just before the bend. When running higher boost will this restrictor need altering?
Dave
Old Aug 5, 2006 | 11:19 PM
RST Ski's Avatar
RST Ski
isnt that just a one way valve?
Old Aug 6, 2006 | 07:57 AM
SafeChav's Avatar
SafeChav
I thought it was just a 90 degree bend, no restrictor as such?
I run silicon pipe straight to mine
Old Aug 6, 2006 | 11:50 AM
Rab's Avatar
Rab
Fucking superstar........
Thats a vaccum breaker valve. It'll be fine
Old Aug 6, 2006 | 06:00 PM
SafeChav's Avatar
SafeChav
A breaker valve??
Explain a little more??
Old Aug 6, 2006 | 07:14 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
some cars ive broken have had propper little valves fitted, i beleve they are early crude was of making the ecu not cut the fueling when the boost is upped
ive got 1 that works like a non variaible bleed valve thats made by TTechnics thats was fitted in the ecu vacumn pipe on a very old skool tuned rs
Old Aug 6, 2006 | 07:18 PM
DazC's Avatar
DazC
Mine was fine with just a straight peice of silicon vacuum tubing.
steve.rst
Mar 15, 2016 08:01 AM
liamT74
Sep 23, 2015 10:24 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
