Can a more powerful car corner faster?
I'm currently having this discussion with someone, and I'm sure there's some physics involved somewhere, but I'll be fucked if I can explain it properly.
We're talking mechanical grip/slip angles/tractive effort etc, and he is claiming that if you take two identical cars one with more power, with the the same weight, tyres, suspension etc - that the more powerful car will be able to corner faster thanks to being able to apply more power post-apex.
I'm trying to limit his argument by suggesting that power aside, the cornering speed is always goverened by the slip angle of the tyre......
What are the physics involved and why?
It's Saturday afternoon and Pon wants to discuss physics
I would have thought it would make no difference and both would corner the same as they are governed by the amount of grip the tyres, suspension etc will allow. As this won't change I don't see how power has any relevence to cornering speed
i not sure rich ..
most people with more power tend to enter the apex faster.. realise they cant corner and fall off
i think tho you would be able to leave the corner faster but dont know how much faster it would be .. suppose its all about how much extra power you have and if the driver is any good..
Originally Posted by Eagle
i not sure rich ..
However, what I'm saying is that reagradless of power, the grip available is surely limited by the adhesion of the contact patch.
The more power, the greater tractive effort applied, therefore you can overcome the slip angle of the tyre, and you lose grip.
if the two cars are limitied by the same levels of grip, downforce etc then the maximum corner speed will still be exactly the same. The same laws of friction still apply if you have a bigger engine. only difference will be when it comes to accelerating out of the bend onto the straight when the faster car starts to be able to use its power again.
a 250cc gp bike corners faster than a 900cc 4 stroke with three times the power yet a 250 being lighter also has smaller tyres.strange but true,and even stranger on many corners the 125 is even quicker on tiny tyres.
bikes are different i know but thought it would add more to your discussion.
Originally Posted by 89XR2
I was told how to work out maximum corner speed by a Police Accident investigator once but I can't for the life of me remember how to do it.
Thing is advances with tyres/suspension/geometry and so on corner speed will increase so a policeman cant work out the max speed on any given corner untill he knows the vehicle, tyres, set-up and so on.........
watch police traffic cops getting trained,where they get them ideas from of how to drive fast is beyond me,its just as well they have radios.
Take my saff (please
) it's running stg 1, and goes round corners OK ish for what it is, if I decide to stg 3 it, it won't get round the corners any faster at all, but it will exit them quicker, probably a lot more sideways than it does now.
surely you are supposed to brake before the corner.. there for your accelarating as you actually enter the corner.therefor the car with more power will actually go round the corner quicker and will have greater corner speed or greater cornering speed if you get hat im saying
) it's running stg 1, and goes round corners OK ish for what it is, if I decide to stg 3 it, it won't get round the corners any faster at all, but it will exit them quicker, probably a lot more sideways than it does now. If you were to radar trap the exit point of a corner, would the more powerful car be travelling faster at that point, assuming everything else bar engine power is equal?
I would say if the ballance or weight distribution of the 1st car is better then the second then this would certainly efect the out come,
I also think that maybe the shape of the car might have some efect if its going quick enough form down force.
Originally Posted by MattRS1600i
To add further fuel to the fire, if its purely dowm to contact patch and grip of tyres, why do people say 4wd cars corner better than 2wd?
With a 2wd if you take that approach when it starts to slide and give it full throttle youre just gonna make matters worse and end up facing the wrong way unless your a good track driver.
Bascily a 4x4 is easier to correct when it starts to go pair shaped so you'll get around the corner at a higher speed than a 2wd that would probably spin off if entering the corner at the same speed!
i think anyways, correct me if i am wrong?
Instead of a corner imagine it as a large roundabout, power will be irrelevent. Max speed will be determined by grip so long as both cars are able to reach a speed great enough to overcome adhesion.
But, as you know, a corner is not about 1 tiny moment, its about the entire process Entry-Apex-Exit .
Ignore the first parts (Braking and trailing throttle up to just before the apex) Its all about the exit. Thats because both cars in our scenario have the same driver, braking ability, and same mass that needs to change direction. Thus the first part of the corner will be the same for both cars. (Yes I realise the more powerful car will arrive faster but for simplicity, lets assume he can only carry X amount of speed on turn in. So his speed at B1 wil be identical)
Anyway
As turning angle decreases, (straighten up) and the driver starts to pick up the throttle, (hopefully those 2 things are inversely proportional to each other. Sadly not always
) the amount of power the tyres can transmit obviously increases, so as one car can accelerate quicker its the point from the the start of aceleration to B2 that will be a shorter time and thus the crucial factor in getting through the whole corner (B1 to B2) the fastest.
make sense?
Anyway
make sense?
One will always be on the brakes at a different time to the other as will the gas.
I actually think there are too many varible for the out come to equal the same.
steve.
COSWORLD
Aug 14, 2015 07:40 AM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
