2wd cossy engine 370bhp rebuilt
Selling my 2wd cossy enigne from my sapp. that was broken.
Engine has been fully rebuilt, with no expense spared.
Head has all new seals, guides, tappets, studs etc,
205 block, new mahle pistons/rings and pins, lightened and balanced conrods, lightened and balanced crank, new bearings/shells, new oil pump etc etc.
Most parts purchased from pjmotorsport, with reciepts.
using triple layer cometics head gasket, and cometic engine gasket set all round. Every sensor has been replaced for a new item.
NEW ESCORT COSWORTH T34 TURBO
MOTORSPORT LIGHT BLUE INJECTORS
909 MOTORSPORT LEADS
4X4 MANIFOLD
POLISHED INLET MANIFOLD
NEW AP 6 PADDLE CLUTCH
BIG WINGED SUMP.
L6 STAGE 3 ECU
3 BAR MAP SENSOR
Enigne has covered approx 3000 miles only including running in.
I shall have it dynoed to make sure the figues are correct and all is well.
I would accept £3000
Any question please ask.
4X4 MANIFOLD
BIG WINGED SUMP.
L6 STAGE 3 ECU
3 BAR MAP SENSOR
rog
Sep 4, 2015 12:10 PM
lockie
Jul 31, 2015 10:03 PM
