FUEL PUMP
i would like to attempt to change fuel pump on my FRST this afternoon depending on the murky weather!!
just any tips or advice from any clever people really
will i need to drop the bloody tank?
thanks
carl
thanks
carl
yes you will need to drop the tank mate as there intank pumps
simple enough to do as long as the bolts come out
think its 2-3 13mm bolts and the tank strap, undo the breathers off the tank and pull the tank down
you will have 2 pipes one red one ehite i think
use 2 very small flat blade scredrivers into the pipe connector and push the pipe should skide off as you push
then take the tank from under car replace pump and refit
Originally Posted by xr2i-carl
only thing is i stuck 40 quid in it yesterday!!!! will that be a problem?
thanks
carl
thanks
carl
id try and drain some out
hmmm, right i wanted to get it done before sunday but aint goin to happen
only reason changin is cuz its fucked
do you think it will be a problem doing the 0-60 strip in a frst with this problem?
thought it would mainly lean off 4th gear full boost?
thansk
carl
thansk
carl
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
