Where is the fuel and pollen filter on a Zetec S
Old Aug 3, 2006 | 07:20 PM
AlexD's Avatar
AlexD
Post Miester !
Default Where is the fuel and pollen filter on a Zetec S
as above, and are they easy to change ??
Al...
Old May 9, 2007 | 08:47 PM
phill295's Avatar
phill295
fuel filter is located under car on passangetr side just infront of the pertol tank and all you need is a torx srewdriver and you fingers but make sure you get the flow the right way
and the pollen filter is also on the passnger side off the car under the bonnet 2 simply clips and then pull the filter out and push the new one in easy
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
gavt123
Sep 5, 2015 10:03 AM
