Series one gearbox into a S2?
Old Jul 31, 2006 | 06:27 PM
matt p's Avatar
matt p
Default Series one gearbox into a S2?
Hi people ive picked up a used S1 box for my S2
and i was wondering whats involved in fitting it?.
Is it a pain in the arse of fairly straight forward with
only a few minor bits that need swapping?.
Thanks in advance matt.
Old Jul 31, 2006 | 10:28 PM
turbo.jon's Avatar
turbo.jon
think its just gearbox mounts that are diff not 100% on that though apart from that should bolt straight on
Old Aug 1, 2006 | 07:29 AM
JesseT's Avatar
JesseT
Straight swap. You'll just get quite a lot shorter gears because of the 4.27 ratio.
Old Aug 1, 2006 | 09:23 AM
antony215's Avatar
antony215
Escort Rs Turbo
S1 mounts and box case are different the s2 uses a cradle under the box s1's dont they use a mount at the front and at the back so it's not a straight swop your better off getting a s2 box mate
Old Aug 1, 2006 | 09:28 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Yup. Won't fit straight in for the reasons above plus gear linkages are different, as is the reverse function. (One reverse gate is in the box, other is in the linkage itself)
Get an S2 box.
Shame you've just paid out for the S1 box, but sure you'll sell it on here once you become a goldmember
Old Aug 1, 2006 | 10:38 AM
JesseT's Avatar
JesseT
The gear linkages are different but doesn't really matter.
Both have 100% certain push down and back reverse. If you don't, then your's broken.
The S2 cradle fits just fine the S1 gearbox. It's a straight fit, but only this direction. The S2 gearbox won't fit the S1, because it has missing the mounting locations.
Old Aug 1, 2006 | 11:09 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Edited. Just had to go check tho...
It's the reverse gate itself that is different between the two cars.
Got confused as my old S2 had a Mk3 gearlever in a Mk4 box and I had to buy a Mk4 lever for my quick-shift for it to fit.
Old Aug 1, 2006 | 02:38 PM
stuart collins's Avatar
stuart collins
mine went straight in mate no problems mate
Old Aug 1, 2006 | 04:03 PM
flashpoint's Avatar
flashpoint
S1 box will fit straight in to an s2 no problem, but not the other way around
Steve
Old Aug 1, 2006 | 08:19 PM
matt p's Avatar
matt p
Cheers guys!!
Me and a mate are gonna do this one weekend soon
he owes me a favour
Cheers again matt
mjonathan24
Oct 29, 2015 10:39 PM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
