h reg moonstone blue 4x4 sapphire cosworth
its a h reg 4x4 sapphire cosworth
spec is as follows:
moonstone blue sapphire cosworth
engine:
recent rebuild from previous owner who knows a1 rallysport guys very well
200 block standard spec bottom end but i do have cosworth forged pistons that can be included 7.2:1 ratio
4x4 head standard
standard cams
everything is standard 4x4 ancilleries in engine bay
803 dark green injectors
level 8 ecu with stage 3 chip setup by my friend neil @ carwise
t3 turbo with big actuator
bailey oil breather/seperator
mongoose 3" full system with 4" rolled out exit
interior is raven leather very good condition apart from drivers bolster which has a rip on it nothing 2 big tho,black pillar trims etc
standard lattice wheels but this may change by time it sells(dont quote me tho)
suspension is koni's all round with i believe 25mm lowering springs fitted
transmission is standard with a quickshift kit fitted
mileage is sowing 25256 but some1 will have tampered with it i thin as bodywork doesnt reflect a 125256mile car,mileage on engine will be around 300mile mark
now for the bits that i wud do if i had the time 2 make it mint
repair the drivers bolster on seat,get part of the door repainted where a previous owner has made a bad job of blending,there is 2 tiny dents on both rear quarters that need repairing,i wud do front brakes so they r like new,couple of bushes on the front and it will drive gorgeous
these are only minor things which are easily done
people who have seen the car can vouch for what ive said(u know who u r so reply haha
4250ono takes it
spec is as follows:
engine:
4x4 head standard
standard cams
)4250ono takes it
lukeeboy149
Aug 22, 2015 04:29 PM
