Anyone else had this from a Mongoose exhaust ?
Old Jul 31, 2006 | 12:23 AM
Modder_J's Avatar
Modder_J
Default Anyone else had this from a Mongoose exhaust ?
I got the 3" bore with 4" tailpipe for my S2 over a year ago (I think), and in the last 6 months (again, I think) the exhaust has split twice.
The first time was where the exaust joins near the tubo, which was welded up as it was blowing quite a bit.
The second time was a few inches lower and was blowing even worse, this has been welded up since.
Just wondering if anyone has had this before ?
Old Jul 31, 2006 | 02:49 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Not sure ive heard of it splitting, but loosening off the turbo elbo nuts is fairly common, all that is needed is a flexy section on the downpipe-centre section, could always try a mongoose downpipe as it has a flexy fitted. another thing to check maintime is engine mounts
Old Jul 31, 2006 | 12:01 PM
Rab's Avatar
Rab
Fucking superstar........
Your engine mounts are shagged mate. The engine is moving too much and causing the exhaust to move. I had this, but it snapped the manifold studs.
Old Jul 31, 2006 | 02:04 PM
RSandy's Avatar
RSandy
yup, engine mounts, i had the same thing, split mount, only mine wore the exhaust housing on the turbo instead n pulled it to bits
Old Aug 9, 2006 | 01:18 AM
Modder_J's Avatar
Modder_J
So its new engine mounts (where can I get 'em from ?)
... and new Mongoose down pipe ?
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
