Replacing valve stem seals in EFI head... Help
Old Jul 30, 2006 | 03:52 PM
spadey's Avatar
spadey
Default Replacing valve stem seals in EFI head... Help
Hi there I have a fiesta rs turbo EFI engine in my cossie replica and its smoking like a bitch!!!! Im pretty sure its the valve stem seals that need replacing and someone has said I dont need to remove the head to replace them I just need a tool which costs about £30 to do it with the head still on"" Basically can anyone give me any info as to where I can buy the tool and also how to do the job with the head still on the car? Any assistance is greatly appreciated as always.........
Old Jul 30, 2006 | 04:04 PM
BRAMMER's Avatar
BRAMMER
burton power sell the tool and yes you can change them with the head on.
Old Jul 30, 2006 | 04:06 PM
spadey's Avatar
spadey
Default re stem seals
Cool, but how? Sorry to sound stupid just wanna get a good idea as to how to do it? Cheers
Old Jul 30, 2006 | 06:07 PM
RST Ski's Avatar
RST Ski
beacuse the cvh spring compressor tool compresses the valve spring from above rather than a normal spring compressor grips the underside of the head, what ever stem seal ur working on, u need to make sure each piston is at tdc or near the top otherwise once the valve is released it will drop down inside the head, then ur head up taking to head off
Old Aug 23, 2006 | 11:12 AM
SafeChav's Avatar
SafeChav
Spin the engine over to its TDC timing mark, then you can do numbers 1 & 4, then you need to spin the bottom end over 180 degrees, and do numbers 2 & 3
Old Aug 23, 2006 | 05:28 PM
Brookesy's Avatar
Brookesy
Better still if you have access to a compressor you can get an airline that screws into the sparkplug hole and fills the combustion chamber with enough air for you to carry out your stem seal replacement
Old Aug 23, 2006 | 06:15 PM
SafeChav's Avatar
SafeChav
You still have to find TDC etc as i said though
Old Sep 2, 2006 | 04:10 PM
daveselwood's Avatar
daveselwood
i got mine from unipart, youll also need a magnetic screw driver to get the collets from the top of the valves
Old May 9, 2007 | 08:36 PM
phill295's Avatar
phill295
as above
Old May 9, 2007 | 09:03 PM
daveselwood
Default air
ive done it loads of times with the tool,but i dont see what the air in combustion chambers does
Old May 9, 2007 | 11:29 PM
SafeChav's Avatar
SafeChav
Stops any possibility of the valves dropping down into the cylinder (but its physically impossible on a standard RST lump as ive tried to lose a valve and couldn't )
Old May 10, 2007 | 09:48 PM
daveselwood
Default air
never thought of that one,i have more of a problem trying not to drop the valve collets so i got a good magnetic screwdriver
Old May 10, 2007 | 11:24 PM
SafeChav's Avatar
SafeChav
put a rag around the spring you are working on.......the ones at the back are the biggest pain in the arse when one drops down the oil return
Old May 11, 2007 | 11:33 AM
Oranoco's Avatar
Oranoco
Take all four plugs out of the engine as well as it makes it a lot easier to turn the engine over by hand. Put a rag round the valve you are working on to prevent the collet dissappearing down an oil way.
Tool is about £10 from and decent MotorFactors. Think mine is a Sykes Picovant and cost me £7 three years ago. Draper one is a bit pants and bent halfway through doing the job
RSmark84
Sep 13, 2015 01:29 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
routemaster
Sep 7, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
