2 ltr zetec bottom end help need urjent!!!!!!!!!!!!!!!
Old Jul 28, 2006 | 08:40 PM
rstgreg's Avatar
rstgreg
Default 2 ltr zetec bottom end help need urjent!!!!!!!!!!!!!!!
right fitted my 2 ltr zvh lump in my cabriolet wired and piped up one problem there is an outlet next to where the oil filter is and its throwing oil out does anyone know wot goes there as im totally lost
Old Jul 29, 2006 | 04:34 PM
tim10_10's Avatar
tim10_10
Is it in a similar place on the block where the oil pressure switch goes? I know there is a blank in one of them on the zetec block and pressure switch in other
Old Jul 29, 2006 | 05:14 PM
rstgreg's Avatar
rstgreg
right next to the oil filter/pump think i sorted it sure it to do with breather system as the oil pressure switch and braided oil line for the turbo come off the same block in the middle of the block with the pipe that goes to the rocker to the right of it with same sort of out let on the right so i have added pipe going to the breather system seems to of have done the job
Old Aug 10, 2006 | 10:43 PM
turbodoctor's Avatar
turbodoctor
help! the block i used on mine didnt have this hole and ive heard loads about it! could be different year maybe? if anyone says i havent looked right take a look for yourselfon my lite linked bellow
Tank Mike
Sep 10, 2015 07:56 AM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
