Help needed. Fiesta RST Engine wiring advice.
Old Jul 27, 2006 | 03:07 PM
Orange Peel's Avatar
Orange Peel
Default Help needed. Fiesta RST Engine wiring advice.
Hi,
My brother recently aquired an Escort Cabby that had been fitted with a Fiesta RST engine. It was running really roughly and not holding boost.
After some investigation he found the 'mechanic' who installed the engine had used the original EFI loom and ECU!!!
My brother has now located the correct ECU but is having problems getting the loom converted.
Can anyone assist us please. Its a lovely car and should be on the road in the weather. Currently its stuck in his garage gathering dust.
Many thanks,
Neil.
Old Jul 28, 2006 | 10:25 AM
Orange Peel
Anyone
Old Jul 28, 2006 | 10:35 AM
vroomtshh's Avatar
vroomtshh
You haven't asked a question? Other than can people assist you. Whats the problems hes having
Old Jul 28, 2006 | 10:48 AM
kjc300's Avatar
kjc300
you dont need to do anything to the loom as long as you have the correct ecu for the loom you have i.e. OFAB or OFAC. you can tell by the map sensors what type you have. you also need the FRST map sensor.
IF you want to run an amal valve - you have to run a wire from the correct ecu pin.
Old Jul 28, 2006 | 03:46 PM
jrs's Avatar
jrs
http://www.fiestaturbo.com/forums/viewtopic.php?t=77331
Old Jul 31, 2006 | 03:43 PM
Orange Peel
Thanks for the info guys
Sorry about not being too specific!! I think the link above is what we are after, so I'll let you know how we get on!
Billy_RS
16
Oct 11, 2025 09:41 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
dlwarrior
Aug 5, 2015 10:19 AM
knight19770
Aug 4, 2015 12:36 PM
