size 4 headbolts for ZVH conversion
Old Jul 27, 2006 | 09:59 AM
Cawood's Avatar
Cawood
Default size 4 headbolts for ZVH conversion
alrite lads
my mate is on with a ZVH conversion, its pretty much finished now
just waiting for the headbolts, he has got some now but they have sent him the wrong size, they are too long
does any one know the correct size the bolts are meant to be?
cheers
Old Jul 27, 2006 | 11:16 AM
T28 RST's Avatar
T28 RST
Ok then
Is this for Gloria
Old Jul 27, 2006 | 11:34 AM
twinkle_2k86's Avatar
twinkle_2k86
when i was doing my ZVH, i had 150 long head bolts
Old Jul 27, 2006 | 02:42 PM
Cawood's Avatar
Cawood
yeah it is davie, theres only him that could buy the wrong ones in the first place lol
cheers twinkle,
anyone else confirm?
Old Jul 28, 2006 | 01:26 PM
Cawood's Avatar
Cawood
is that including the head of the bolt twinke?
Old Jul 28, 2006 | 01:36 PM
twinkle_2k86
no, the measurement is taken from the bottom of the head of the bolt to the end of the thread.
standard CVH head bolts are 135mm long, and for a ZVH you need 150mm long.
you will need to get the right grade of bolt as well tho, i used 12.9 grade bolts which where the allen key type ones, you can get them from Burton for about Ł30 the set, or do what i did, go to your local nut and bolt place, i got my set for Ł8.50 the lot and my mate had the burton ones and there the same bolt made by the same people.
Old Jul 28, 2006 | 04:23 PM
Cawood's Avatar
Cawood
thanks twinkle for that! its for rayner
think ill post this up on escortrsturbo.co.uk for him
he says hes already got 150mm but they seem too long n just bottom out
Old Jul 28, 2006 | 04:26 PM
ballin's Avatar
ballin
yeah you need 150mm for definate.
can get them from burton part # CV191HDL
Old Jul 28, 2006 | 04:42 PM
Wazzzer's Avatar
Wazzzer
have you used the washers with the head bolts...
or you could have fluid (ie oil water) in the threads and its hydrolocking, if there is your bolt could end up like this...
Old Jul 31, 2006 | 11:17 AM
rayner's Avatar
rayner
cheers guys
mk3ste
Oct 17, 2021 10:09 AM
boeb
Jan 9, 2020 05:11 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
