water wetter
anyone used this stuff and does it actually work?
is it safe to use on our engines, also do you mix it with anti-freeze or plain water for the best results?
thanks
thanks
what you doing in here...lol
dave its meant to keep coolant temps in the summer, think they use it in hot countries which is why you've probably never heard of it....
its in the demon tweaks cat I believe.
i've used it and infact i have it in the system this year. the difference is only marginal because its in with the anti freeze/water mix. the best results come when using just water and no anti freeze! dont get it from demon tweeks cos its too damn expensive! get it off fleabay for £4.50!
Don't ask - I don't know
Originally Posted by Alex zvh cabrio
my piss would be better to use
with the lack of air flow to the rad on the escorts then it makes it that much hotter, agree it dosnt usually get that hot in this country but the shit design of these cars mean we have to take measures to keep cool.
S2 btw
S2 btw
i have just sorted up m8s s2 this weekend it had an pro alloy i/c on it with std rad and it was running quite hot last few weeks no cut out bummper.so just put an new pro alloy rad on it with 82 thrmosat on it temps come right down now
it does actually work, was mainly used in race applications a lot of people that run hondas on trackdays use it over here as exploding rads on civics are a common occurence
as has been previously said its available from demon tweeks
i have there rad and am gonna order there front mount but was told by someone that there not that good, although apart from that not heard any bad points on em..
Mark RS
Oct 12, 2015 06:01 AM
