RS Engine build with a difference PARTS NEEDED
Right I have had enough of KE Jet and I want to build a turbo engine with a difference for a shell I have not brought yet. I plant to build the engine within a stand and try to get it running in my garage while I source a good MK4 estate or escort to put it in.
I am trying to do this on a budget and it is a big list but I am hoping someone or loads of them will be able to help me and I can get it going.
List
RS Turbo fuel pump
Fuel pressure regulator
Fuel pressure guage
XR2 head and carb (need it rejetting to run a turbo) or RST head and XR2 Carb & Inlet & dizzy
T3 turbo unit and manifold in reasonable condition
RS Turbo Piston Rings (STD)
RS Turbo Crank Bearings (STD)
RS Turbo STD Oil Pump
RS Turbo Water Pump
RS Turbo S1 Scorpian Exhaust (Full)
Head gasket Set XR2
Nitrous Oxide Kit
Motorsport Leads
Group A Coil
Decent AFR Guage and sensor
Fuel pipe and accessory fittings
And I am sure I have missed a few things out. All needed at reasonable prices in the Birmingham Area over the next few months!
CheeRS
List
RS Turbo fuel pump
Fuel pressure guage
RS Turbo Water Pump
Head gasket Set XR2
Nitrous Oxide Kit
Motorsport Leads
Group A Coil
CheeRS
i got, head ,turbo, bottom end, and a set of twin 40 carbs with fuel pump and pressure regulator with a manifold made up to turbo through the carbs
rs turbo head set aswell
JoeyBoyden
Jan 4, 2024 02:36 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
