Urgent help needed,Diesel Van!Please!
Right ive got a 1.9 diesel scudo van,and earlier the starter engaged without any key or anything(it was just parked up) it was in gear and started to leap forward then it stopped an smoke came from the bonnet!The smoke was caused by the earth from the battery to gear box melting,as it was shorting out(on the body)...would his cause the starter to engage?
Or it could of been shorting on the positive terminal of the battery...im not sure
Anyways ive replaced the earth cable but now i think the batterey's flat...or do i have another problem! Ive never known anything like this!
Please help i need to get is sorted!
I'm no expert but I don't see that it could short circuit by the earth strap touching the body - both bits should be common earth. Sounds more like there is something feeding power to the starter.
Scary that it is possible all the same.
The Enigma
13
Aug 20, 2015 09:38 PM
