Advice on lazy cvh rocker please!
Old Jul 23, 2006 | 10:14 PM
~nomad~'s Avatar
~nomad~
Default Advice on lazy cvh rocker please!
Had a look at my cvh turbo's head today, as there is a tapping when the engine is cold, was told this is a lazy rocker. I am no expert on these things but saw this:
all the other ones are "down", so i presume this is the lazy rocker? anyone advise on whats going on and how i fix it?
Old Jul 23, 2006 | 10:17 PM
MAD EVO 4's Avatar
MAD EVO 4
New set of hydraulic tappets bro
Old Jul 23, 2006 | 10:20 PM
Lee Reynolds's Avatar
Lee Reynolds
Cant see what your seeing there as a problem.? The hydraulic tappets compress when opening the valve........
Old Jul 23, 2006 | 10:31 PM
~nomad~'s Avatar
~nomad~
thats the only one thats up like that. tappets are pretty new, can i replace one?
Old Jul 23, 2006 | 10:33 PM
EIL132's Avatar
EIL132
From a picture it's impossible to see, could be the cam lobe or tappet
biglee's Avatar
biglee
Audio specialist
thats perfectly normal matey.....
Old Jul 23, 2006 | 10:35 PM
Lee Reynolds
no a cam a followers must be renewed together. The one that is squashed so to speak is opening a valve. Put a spanner on the pully and turn the engine with it...youll see it some back out....
Old Jul 23, 2006 | 10:38 PM
~nomad~'s Avatar
~nomad~
cool, will try that tomorrow. The tapping only lasts a couple mins till the car warms up, then its fine. was told maybe the tappet wasnt holding oil till it was warm?
Old Jul 23, 2006 | 10:47 PM
Rick's Avatar
Rick
It's draining off. Don't worry about it.
Old Jul 24, 2006 | 08:21 PM
DazC's Avatar
DazC
How long had the car been stood with the engine switched off before you found that?
Old Jul 24, 2006 | 08:24 PM
~nomad~'s Avatar
~nomad~
about 3 weeks.
Old Jul 24, 2006 | 08:47 PM
Oranoco's Avatar
Oranoco
My brothers has a tappet that clatters it's tits off for a couple of seconds on startup from cold and is then silent. It doesn't seem to be causing any problems so it's been left alone
Old Jul 24, 2006 | 09:16 PM
DazC's Avatar
DazC
about 3 weeks.
The tension of the valve spring could have squeezed all the oil out of it. The tappets should remain quite solid and not compress like in your picture. If they compress like that, its lost all it's oil and needs the oil pressure for it to re adjust itself.
Old Jul 24, 2006 | 09:17 PM
morto's Avatar
morto
sounds normal to me, take it a spin and give it a good thrash if it sounds ok after that its fine , just a cvh
andy
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
