ONE dead cossie!!!!!
orion=mini saff
ok,that would be my piston!!
ah well,least i wasted the scooby!!
thts my piston!!!
thts the view from the side of my block!!!
i dont think she will make it to ford fair
new engine needed,not even chemical metal will stick tht back together
thts my piston!!!
Originally Posted by orion_crazy_carl
yeah,might aswell do it proper as it was running T35,stage 3,pace cooler ect ect on a std engine!
lasted 2 days
lasted 2 days
orion=mini saff
lasted 2 days
lasted 2 days
thts my piston!!!
thts my piston!!!
staffi
he maybe but im hearing alot of reports of em blowing up now.getting old and unrelaible like the cossies did!
If the rods gone flying thru the block its most likely to be a oil problem, as the crank wouldve picked up the rod and flung it sideways thru the block.
Wouldve happened regardless of the power TBH, not like you was pushing the limits of the engine at that spec.
orion=mini saff
as said the scooby may still be going,but he did get blown away by a old taxi
and i will be back bigger and better,scoobys are just another car on the roads,
cossies are heritage,and race bred beasts!
cheers for the support guys,on the hunt still,not much about mind
orion_crazy_carl
you will find something soon mate,dont dispair.
the oil pressure guage prob wouldnt have helped by then,it only takes a bit when you are gunning it and its all over.you prob wouldnt have caught it in time at that speed.
orion=mini saff
but far as i knew the pressure could of been low from the start off,so i may of been able to stop it
aw well,to late for what ifs,now its time for"wheres my cheque book!"
oh yes,but my god it was running so sweet,and went like fook,real shame!
bugger, but aint that allways the way of engines, they sound and run there best just before they let go
orion=mini saff
yeah smit,be a mate and lend out
once again cheers for the support,nice to know were all used to it
but i wouldnt change her for the world!
engine possible....
engine possible....
Russ Payne
Sep 25, 2015 08:29 PM
