6-pot AP Calipers what
Old Jul 22, 2006 | 08:50 PM
Default 6-pot AP Calipers what
size disc can be fitted, 330 was max with my Rondells whats the next size up & will they fit under 17" Supperleggaras. I appear to have a more clearance is that so.
Thanks Rod
Old Jul 22, 2006 | 09:06 PM
Cam's Avatar
Cam
343mm discs will just fit under 17 Oz alloys with CP555s IIRC but 355s will not
Old Jul 22, 2006 | 09:38 PM
Thanks do AP do that size.
Old Jul 22, 2006 | 09:42 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Yes they do, you should go for 32mm width if your calipers will allow. You could get big gains just by changing pad material obviously this depends on what pads you use at the mo.
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
