temp
Old Jul 21, 2006 | 11:08 PM
NEWTON's Avatar
NEWTON
Default temp
any one know what 200f is in degrees my temp gauge went there today cheers
Old Jul 21, 2006 | 11:22 PM
TURBO BOI's Avatar
TURBO BOI
200 degree Fahrenheit = 93.3 degree Celsius
Old Jul 21, 2006 | 11:24 PM
NEWTON's Avatar
NEWTON
would you say thats ok then?
Old Jul 21, 2006 | 11:25 PM
TURBO BOI's Avatar
TURBO BOI
water temp guage? seems ok to me, most cars run around 90c
Old Jul 21, 2006 | 11:26 PM
NEWTON's Avatar
NEWTON
water temp guage? or outside temp?
water temp mate
Old Jul 21, 2006 | 11:27 PM
TURBO BOI's Avatar
TURBO BOI
yep normal
Old Jul 21, 2006 | 11:32 PM
NEWTON's Avatar
NEWTON
yep normal
thats with the fan on,is there another fan switch i could use so it would come in quicker??
Old Jul 21, 2006 | 11:38 PM
TURBO BOI's Avatar
TURBO BOI
u can get aftermarket ones yes that work at different temps, i know some1 who has just bought one for a non-ford
or you could have the fan on a switch aswell
Old Jul 21, 2006 | 11:42 PM
NEWTON's Avatar
NEWTON
cheers mate ill have a look,just thought it mite have been running hotter today with this weather,worried as it a new engine spent loads of cash on a resore of my s1
Old Jul 21, 2006 | 11:44 PM
TURBO BOI's Avatar
TURBO BOI
i see, i wudnt worry to much as around 90c is pretty good running temp as ur fan cuts it ok too, do you have a after market guage on urs?
Old Jul 21, 2006 | 11:47 PM
NEWTON's Avatar
NEWTON
yeah mate i have the autometer pro comp range ,water temp,boost,oil pressure,oil temp and air/fuel ratio so the engine is well moniterd,on a run in map at mo on gotech
Old Jul 21, 2006 | 11:50 PM
TURBO BOI's Avatar
TURBO BOI
very nice, i got standard temp guage at the mo, ill be lucky to see the needle move at all on mine
Old Jul 21, 2006 | 11:54 PM
NEWTON's Avatar
NEWTON
crappy standard gauges never right mate get a good one worth it in the end
Old Jul 22, 2006 | 08:11 AM
NUTS RuS's Avatar
NUTS RuS
My ECU only cuts my fan in at 204 degrees so no need to worry about 200
Old Jul 22, 2006 | 11:23 AM
SafeChav's Avatar
SafeChav
You can easily put a bypass switch in, the fan will still be able to operate as normal and turn off with the ignition, but you can override at any time
Its only running one wire from the fan plug to inside the car.....
Old Jul 22, 2006 | 04:46 PM
NEWTON's Avatar
NEWTON
cheers lad thanks,was just worried as new engine
Mark RS
Oct 12, 2015 06:01 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
Ben26
Sep 3, 2015 07:55 PM
