cosworth front brakes
Old Jul 21, 2006 | 04:50 PM
andyt's Avatar
andyt
Default cosworth front brakes
right then peeps
what brackets do you need to fit 4 pot 2wd cossie front callipers to a series 1
or im i better putting series 2 callipers on
thanks in advance
Old Jul 21, 2006 | 04:51 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
2wd calipers won't fit, need to use 4wd with 2wd discs.
Old Jul 21, 2006 | 04:56 PM
andyt's Avatar
andyt
thanks Stu
what brackets do you need aswell mate
Old Jul 21, 2006 | 05:44 PM
Mr S1's Avatar
Mr S1
Originally Posted by andyt
thanks Stu
They bolt straight on mate, no messing about and no brackets needed. The discs are FT (fuckin tight) as far as fit goes, some have 2mm taken off the edge but I never bothered.
Old Jul 21, 2006 | 05:53 PM
andyt's Avatar
andyt
cheers Stuart
and get your S1 pics up in the pics and video sect
Old Jul 21, 2006 | 05:58 PM
Mr S1's Avatar
Mr S1
no sweat
And if anyone wants to see my car, click the link in my sig
Old Jul 21, 2006 | 06:10 PM
JamboRS's Avatar
JamboRS
focus rs 1672
4 pots will fit
i bought mine already on the hub but im sure its just bigger bolts holding them on,i have alloy bells aswell
check my resto in the restorations and rebuilds
Old Jul 21, 2006 | 06:18 PM
Mr S1's Avatar
Mr S1
Originally Posted by JamboRST
4 pots will fit
Yeah but Andy's running standard rims etc..........and there ain't no way 4pots fit behind those
Old Jul 21, 2006 | 08:23 PM
JamboRS's Avatar
JamboRS
focus rs 1672
4 pots will fit
im sure they fit with a spacer
what size wheels do cossies come with?
Old Jul 21, 2006 | 08:45 PM
DaveyBoyS1's Avatar
DaveyBoyS1
2wd 4pots do not fit behind the standard wheels.
They need 4mm machining off the mating face of the caliper and the hubs need drilling to 14mm (don't quote me on that)...
I did the 2wd caliper conversion on my s1... i found out that you have to bin the standard wheels the hard way
But... once on and working, boy do they stop IMO the most cost effective way of making a rst stop... if you don't mind loosing the standard wheels. Been in an rst with 4wd calipers and IMO theres no comparison
Old Jul 21, 2006 | 09:14 PM
bigmatt-s2rst's Avatar
bigmatt-s2rst
i wa just gunna ask this!!!
ive got some 4 pots but i dont wanna lose the standard rims!!!
back to the drawing board
Old Jul 22, 2006 | 09:38 AM
SafeChav's Avatar
SafeChav
Firstly 4 pots will fit on, secondly they will fit behind standard rims but you need some fairly big ass spacers so for standard rims its not really a good idea.
To fit 4 pots, you have to skim 3-4mm off the caliper face, and tap the hub with M12 threads, and get some cutoms pipes
A bit like this:
Old Jul 22, 2006 | 03:41 PM
DaveyBoyS1's Avatar
DaveyBoyS1
Because it makes the wheels stick out and foul the arches
original
Apr 28, 2026 05:20 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Aug 14, 2015 07:29 AM
Aug 10, 2015 12:08 PM
