How to install ARP Head Stud Kit
What's the correct way of installing the kit? The Torque given in the manual is 81NM. Should I still torque them up in 4 stages like the standard bolts?
What settings should then be used?
Should I use engine oil or special lubricant for better friction and where do I have to put it
first you should clean the theards
then put on each of the studs some lub an tight them to the block by hand ONLY!! until they wont turn any more
then fit the head and put some lub on the upper therd and fit the washers and the nuts then tourq them to 65 lb/ft
FOR BEST RESULTS USE ONLY!!! THE ARP LUB
hope that i helped
freddy
hope that i helped
freddy
jonfoc
16
Sep 11, 2018 05:35 PM
