Who can fix a L6 ecu?
Old Jul 18, 2006 | 04:35 PM
willie rae's Avatar
willie rae
Default Who can fix a L6 ecu?
MY ecu is not firing the injectors who can fix this?
cheers
Old Jul 18, 2006 | 04:37 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Harvey Gibbs at SCS (if it is fixable) call him tomorrow on 01733 576 614 .
Old Jul 18, 2006 | 04:39 PM
willie rae's Avatar
willie rae
cheers mike
Old Jul 18, 2006 | 05:49 PM
Tangodeltasierra3's Avatar
Tangodeltasierra3
Or buy mine at Ł100.
Old Jul 18, 2006 | 05:52 PM
Graceland's Avatar
Graceland
Team HOTHOT!
before you decide its broken, have you checked the fuse for the fuel pump, injectors, other sensors relay? its one of the 2 fuses found on the actual engine loom not too far from the ecu plug. If one of these is popped, then you won't have no fuel pump running, or injectors firing
Old Jul 18, 2006 | 07:08 PM
ECU Monitor Enthusiast
TRANSLATION
Send it to Harvey who will only send it to Ahmed and get him to fix it then
charge you an additional mark up fee then send it back.
As much as I like Harvey, he is not an electronics engineer.
I would advise....
Check the chip is seated correctly and you dont have a loom or sensor
fault BEFORE sending back an ecu which is probally ok.
(as Graceland has already said)
Try to borrow another ecu from a mate and try with another chip and
substitute changing your chip over of course aswell as another test.
IF you must send it for repair, get a quote in writing first as it may be
cheaper to buy a second hand one if in the unlikely event your ecu is dead.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
Russ Payne
Sep 25, 2015 08:29 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
