drilling and tappinm zetec head to take erst manifold ?
Old Jul 17, 2006 | 11:55 AM
luke89's Avatar
luke89
Team HOTHOT!
Default drilling and tappinm zetec head to take erst manifold ?
any one no what size drill bit and tap i should use and im sure i need to use a M8 tread size but just want to check before i mess things up lol
thanks
Old Jul 17, 2006 | 11:59 AM
Garage19's Avatar
Garage19
From memory.
M8 x 1.25 tap which has a drilling size of 6.8mm.
I would double check though.
Old Jul 17, 2006 | 12:03 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
buy an adaptor plate, far easier than fucking about drilling/tapping it.
plush if something happens and you bend the valves etc yo dont have to do it all again
Old Jul 17, 2006 | 12:10 PM
Garage19's Avatar
Garage19
Wimp!!
It is a 20 min job but not something you should atempt with your black and decker cordless. At the least, take the time to set the face up square under a pillar drill.
You will break through into a oil way so need to flush out the head afterwards. Then use new head studs and arraldite them in to seal.
Old Jul 17, 2006 | 12:42 PM
luke89's Avatar
luke89
Team HOTHOT!
fudgeass not anothe space to fit one on the fiesta mate or the turbo hits the rad head will be removed to fit de-comp plate anyways so will ask my mate to drill it at work thanks
Old Jul 17, 2006 | 01:16 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
move the rad
JK12
33
Apr 26, 2021 12:09 PM
yatta
May 21, 2016 10:31 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
