agggggggghhhhhhhhh bloody car
right...
the fucking thing wnt start agin now just turns off.
have had a play this morning.
basically.
fuel pump primes and desnt if i disconnect fuel relay s i presume thats k.
have high pressure at either end of fuel filter, but on a dribble at tp of metering head and at injectors.
car will only start and runif butterfly under air filter is held down but 10mm.
car will nt start with cold start discnnected.
s i am presuming a metering head fault.
anyother things to check or change.
plugs and leads all look ok so does dizzy cap and rotor arm.
help please its doing my nut in.
thanks
basically.
thanks
it will run, but only with the buterfly pushed in, without it the car just revs up on throttle but seconds later dies again.
cant see how co could have changed, was fine yesterday morning.
cheers mate. I actually bought car from cleavdon, its a bit of a shed but its a project to do ver next few months, so trying to get it up and running properly before i start doing anything.
the wireing etc is pretty bodged and car needs general tidy up.
U may recgonise reg.. RHO 69G.
Originally Posted by SafeChav
Does the flap move when you crank as said?
Checkk all the boost hoses are on, then you could disconnect everything from the engine such as the brake servo etc, if you are running the standard breather set up even the engine itself has many potential air leaks.....
spot on.
bottom boost hose was split. changed and fine again, obo been like it a while as idle is now too high and its running rich. The spilt has obo got bigger.
cheers guys
cheers guys
steerfromdarear
28
Jan 29, 2016 06:14 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
