whats afr?
Old Jul 16, 2006 | 09:16 AM
CJBear's Avatar
CJBear
Default whats afr?
I keep reading about AFR everywhere specially with tuning turbos and have no idea what you all on about, so far i have learnt its not actually Angry Fucking Rage when things go wrong, corrected its Air Fuel Ratio?
So what is good AFR? does it apply to all engines and how does it affect power and all that other stuff when tuning?
Old Jul 16, 2006 | 09:21 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Re: whats afr?
Originally Posted by CJBear
its Air Fuel Ratio?
Correct
Steve.
Old Jul 16, 2006 | 09:39 AM
Jay,'s Avatar
Jay,
Sponsor
good afr differs from turbo to none turbo
http://www.zeitronix.com/
Old Jul 16, 2006 | 12:30 PM
At a basic level, an AFR of 12.5 is optimum for making peak power from an engine, but the amount of heat generated at this level can be too much in turbo engines (or even when totally flat out for an N/A engine) so people tend to run a richer mixture (lower number) to help control the heat.
Turbo motors typically will be mid 11s when flat out, but in some cases where the engine is badly designed in terms of manifolds or similar (Focus RS being a good example Stu mentioned) you may have to dip into the 10s to keep exhaust gas temperatures at a reliable level.
Old Jul 16, 2006 | 12:45 PM
CJBear's Avatar
CJBear
rightyo so lower the AFR number the richer the mixture is, higher number leaner it is.
does the same figures apply to say a V12, V8, Straight 6, V6 all the way down to bikes? if not how the hell you know what it ment to be?
Old Jul 16, 2006 | 12:48 PM
The same figure for peak power applies to all cars using petrol, although i would imagine it varies very slightly based on octane rating etc.
HOWEVER, thats only the thoeretical peak, and with regards to the temperature side of things, the way you know what it should be is by being a talented tuner with 20 years experience
Old Jul 16, 2006 | 01:01 PM
CJBear's Avatar
CJBear
true experience counts for everything, just trying to understand a bit more the hows and whys behind things
Old Jul 16, 2006 | 01:10 PM
Thats what we are all here for mate, welcome to the site
Old Jul 16, 2006 | 05:11 PM
CJBear's Avatar
CJBear
Thanks Chip-3door!
This stuff really facinates me, have so many questions on things i do not get. Only so much my limited brain can absorb through books, often leaving me more baffled than i started off with
Old Jul 16, 2006 | 05:15 PM
LOL, yeah it can be a bit like that.
Im in london most weeks, if you fancy discussing it over a pint one evening then let me know cause ive usually got feck all to do of an evening anyway while im working away!
Old Jul 16, 2006 | 05:42 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
and there it is,....
a truly classic "hit"
start with being friendly, (in some cases a shoulder to cry on) then when the "victim" is not expecting it,....BAM,....
lets go out for a drink.....
before they know it, the innocent party is bent over a sofa in room No 30 of the nearest travel lodge.....
however, chip seems to know a thing or 2 so being butt raped for free info isnt that bad....
Old Jul 16, 2006 | 06:07 PM
Jim Galbally's Avatar
Jim Galbally
just incase youre not sure
air to fuel ration of 15:1 means 15 "parts" of air to 1 "part" of fuel
i know 99% of people might already realise that, but not everyone will unless it's said...
Old Jul 16, 2006 | 06:16 PM
UBster's Avatar
UBster
lol
Old Jul 16, 2006 | 06:20 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Im sorry but thats THE funniest thing ive read in ages
Old Jul 17, 2006 | 01:33 AM
PMSL
only if she isnt old enough to drive
Old Jul 17, 2006 | 09:53 AM
CJBear's Avatar
CJBear
poo the bed
Old Jul 17, 2006 | 10:14 AM
CJBear's Avatar
CJBear
thought it was one way or the other
Old Jul 17, 2006 | 10:27 AM
foreigneRS's Avatar
foreigneRS
Testing the future
yes jim, but that 'part' is a mass, not a volume
Old Jul 17, 2006 | 09:52 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
PMSL
Chas
Oct 5, 2015 07:13 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
Red_bull
Aug 25, 2015 06:27 PM
Fiecos Dan
57
Oct 22, 2006 09:18 PM
