T34 v T28
As you all know i have a T28 turbo on the car, would i benefit in anyway if i put a T34 on it
Would it be more laggy
Would it give me more top end power
Would it do nothing at all
Here is the current spec
1618cc CVH, stage 2 big valve head (ported and polished), Newman cam, solid lifters, piper vernier, wire ringed block, lowered compression(7.5:1), ARP conrod Bolts, heavy duty bearings, high pressure oil pump, AVA ecu, 7000rpm limiter, AVA modified fuel system, AVA high flow tubular manifold, T28 turbo, 360 bearing, reshaped cosworth front pipe, AVA Large capacity intercooler, samco water and boost hoses, magnecor leads, magnex exhaust, modified airbox.
Its making 205 ATW with 16psi boost
Just curious
Just curious
got my car with a 'straight t3' , o.48 hot and o.42 cold side
use to spin into third at the strip
fiited a hybrid t3/t4 0.48 hot and 0.60 cold
spins less low down and goes better at the top
starts boosting at 2k , 0.5 at 3k , hard boost after that!
Originally Posted by reality
I highly doubt you'd hit full boost until 4000rpm on a 1.6 with a T34..
go for a rollerbearing fuck all lag and still makes the power
davie why go for a t34 when a stg 3 t3 would be sufficient
as for boost,is your boost not limited because the head or block(or both were skimmed) when you blew a head gasket,would still make more power on a stg t3 at that boost anyway
ive got a t34,
and the bost delivery is very violent,
but i do have positive boost by three, and it peaked at 1.6 (more than i want to run) by 3600 yezsturday in third, and holds that boost till the red line.
its also worth considering that a t34 will make more power than a stg3 t3 at the ssame boost,
go for it aslong as you dont use the car as a daily runner
Originally Posted by zippyobrien
ive got a t34,
peak power isnt everthing,and i still say a t34 is far to big a turbo for a 1.6 running 16psi of boost
i would agree, but im runnig closer to 25 so its not a problem for my car, and its only a week end toy,
although i dont think its any more laggy than my old completetly standard rs turbo
Russ Payne
Sep 25, 2015 08:29 PM
