RS Turbo Chip
Does anyone know what this chip is for or what it will fit,i'm looking for one for my S1 but the numbers mean nothing to me !! Here is the link
http://cgi.ebay.co.uk/RS-Turbo-Escor...QQcmdZViewItem
Yeah fair play,i was just curious,i'm have'nt yet decided if i'm gonna chip my car,everything is standard at the moment and the engine/clutch will likely last longer if i leave it be,just so tempting when it's so easy to do
Get a proper Stage 1 chip from someone like Turbosystems, they will do an exchange ECU I imagine. Then get it fitted along with a -31 Actuator and a brass 3-way lockable bleed-valve. Once thats done, have a proper RR tune by someone who knows what they are doing (like us!!) and you should see around 30-35bhp above standard. Not really any nasty stress on the engine at that point providing its in reasonable condition and looked after and it will put a grin on your face!
Worth renewing the fuel pump though if there is no record of it having been done.
Originally Posted by craig_007
Thanks for that,where are you based about as i'm up in Fife
contact number 01418485257 ask to speak to alan or colin
think there chips are £210 including set up,well was in 2002 when i got mine done
Did they also supply the uprated actuator or am i better just buying and fitting one on my own,do you have any idea what chip ava used and more importantly what like did your car go and drive
Cheers Craig
Cheers Craig
Cheers Craig
Cheers Craig
ava make there own chips
Although at Stage 1 you could use the add-on board, to remove the boost-cut.
JK12
33
Apr 26, 2021 12:09 PM
big_Rad
Sep 15, 2017 09:36 AM
cossie09
Oct 11, 2015 06:32 PM
Matt Baxter
Sep 16, 2015 08:30 PM
cossie09
Sep 14, 2015 04:21 PM
