2wd rear brake dust shields cossie(do you need them???)
Old Jul 15, 2006 | 03:20 PM
fatboyz's Avatar
fatboyz
Default 2wd rear brake dust shields cossie(do you need them???)
hi people im trying to put my 2wd saff together but the rear disc dust shield thingys are really rusty do i need to get some more(if they still sell em ) or is it ok and safe (mot wise) to run the car without them ?
cheeRS
Old Jul 15, 2006 | 03:23 PM
mattbibs's Avatar
mattbibs
interested in this myself - think i'll leave them off if i can!
sorry to jump in - but as i need new discs and calipers is it worthwhile to upgrade to the 4x4 items?
Old Jul 15, 2006 | 03:28 PM
cossie550+'s Avatar
cossie550+
leave them off and then fit bigger discs
Old Jul 15, 2006 | 03:29 PM
fatboyz's Avatar
fatboyz
no probs mate
i didnt know 4x4 ones were any better
Old Jul 15, 2006 | 03:30 PM
mattbibs's Avatar
mattbibs
been told they are better but been so long i cant remember why!
Old Jul 15, 2006 | 03:52 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
4x4 rear brake set up is better because you can run a vented disc which helps diperse heat. This obviously prolongs the life of the pads and helps stop the brake fluid reaching ridiculous temps.
Old Jul 15, 2006 | 04:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
they are only there to stop crap from getting into the back of the disc
you can run normal sierra ones if you want to run new stuff (i've done it on the twinkly) but if you want to fit bigger discs you will need to bin them anyway as they get in the way
besides, there was an article way way back in some mag that said binning the dust sheilds made the brakes more effective as they let more air to the disc and let them cool down better
Old Jul 15, 2006 | 07:41 PM
Mr C's Avatar
Mr C
bin them mine were a pain in the arse, rotten muck, need to remove the hub though if I remember
Old Jul 15, 2006 | 08:06 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
you dont have them on the fronts do you, so bin em off.
BUT i have been told that the 1mm thickness of them does something with the wheels/camber so i am going to cut mine off around the hubs so that there is stil the 1mm bit of plate, but just no sheild
only difference between 4x4 and 2wd rears is that the 4x4 uses a vented disc and wider calliper.
Old Jul 15, 2006 | 08:07 PM
lamb chops's Avatar
lamb chops
I chucked mine away on my old saff, didnt miss them
Old Jul 15, 2006 | 11:48 PM
dojj's Avatar
dojj
it just means the track at the rear is that thickness wider if you keep the plate and cut the rest off
at least that way you don't need to mess about taking the hub to bits
Old Jul 15, 2006 | 11:51 PM
SPADGE's Avatar
SPADGE
Yep get the grinder out and cut the shonky things off
Take your time and make a neat job of it and try to avoid the brake lines
Old Jul 16, 2006 | 05:37 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
my rear arms are on the garage floor, so should be easy lol
just poly bushed em too
Old Jul 16, 2006 | 05:56 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
I now feel better, i`ve just done the whole back end of my car and left them of, i didnt think there would be a problem
original
Apr 28, 2026 05:20 PM
rog
Aug 30, 2015 05:32 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
