L8 & P8 ecu
Old Jul 15, 2006 | 11:10 AM
Badman38's Avatar
Badman38
Default L8 & P8 ecu
what needs to be done to the L8 and P8 ecu to run 750cc injectors and a coil pack plus what are the Associated costs.
Old Jul 15, 2006 | 11:31 AM
Badman38's Avatar
Badman38
Old Jul 15, 2006 | 12:08 PM
Ryan's Avatar
Ryan
think both can run 750CC without any hardwaremods.
p8 can run a coilpack with the correct board
and l8 can run a coilpack with a secs or PB labs board i believe
Old Jul 16, 2006 | 09:44 AM
DazC's Avatar
DazC
Both run the injectors without modifications. They both need a live map and ideally off boost closed loop fuel control (Lambda).
P8 can run coilpack without modifications but needs software changes and obviously the coil pack and wiring.
L8 needs the coil pack driver board and then the coil pack and wiring.
For costs, speak to Stu at MSD.
Old Jul 16, 2006 | 10:47 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Use a P8 Sean,
Then you have all the extras at your fingure tips.
Or speak to RPlabs. He can mod a L8 to run a coilpack, ALS, 8 injectors, Air injectors etc..etc...
Price works out the same for either a P8 with board to run coil pack.
Or mods to a L8 from RPlabs.
Old Jul 16, 2006 | 10:50 AM
Stu @ M Developments's Avatar
PassionFords Creator
Just to correct that, the P8 doesnt need a board to run coilpacks.
The rest of teh info in this topic is accurate though.
Old Jul 16, 2006 | 10:58 AM
Versus_Creations
Ask me a question!
Yes i know Stu. But the person who maps Sean's car will want a board inside. Also Sean will want extras that is available using the Pectel board in a P8 as i know he loves gadgets.
To be able to run a coil pack without a board requires lots of time from the mapper which costs more money than fitting a pectel board.
For this reason fit a Pectel board and pay fook all for mapping
Old Jul 16, 2006 | 11:15 AM
Sorry Jano, your not quite up to speed on this occasion.
The P8 board does'nt add any extra features to the ecu mate, im unsure why you would think it does?
As for teh lots of extra time from the mapper. changing a decimal value from 09 to 33 doesnt exactly take a lot of time does it? In fact, i will lay you a nice bet on teh fact i could do it faster than you can fit and secure a board properly into a P8.
Old Jul 16, 2006 | 11:20 AM
Versus_Creations
Ask me a question!
Will you be able to make the pectel/secs monitor and datalog work on his motor without the board?
Old Jul 16, 2006 | 11:21 AM
Versus_Creations
Ask me a question!
Just incase you missed the fact the mapper will want a board.
Old Jul 16, 2006 | 11:23 AM
Yes mate, no problem.
Old Jul 16, 2006 | 11:24 AM
Didnt miss it pal, just pointing out that what you said was incorrect, there is no mapping needed at all to enable coilpacks, and the board does NOT add any extra functionality to the P8.
Old Jul 16, 2006 | 11:26 AM
Versus_Creations
Ask me a question!
koool
ok just roughly how much to mod the ECU for all extras and mapp to spec.
Old Jul 16, 2006 | 11:34 AM
Varies too much to quote. Road or brunters for starters?
Coilpacks dont cost any extra to implement at all. Closed loop is also a standard feature on P8 so is another cost free feature of P8.
ALS mapping costs extra depending on how much work is required and how extreme you require it to be.
Biggest problem with P8 is its bloody unreliable. Had more P8 failures than all the L series ECU's put together. In fact, probably 10x more.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
