Vauxhall Corsa's
Old Jul 14, 2006 | 10:21 PM
Trev's Avatar
Trev
Default Vauxhall Corsa's
I know its not the right place to talk about the above but my girlfriends 1.0 3 cyl job is leaking oil from a large pipe at the front of the engine? The pipe looks like it is just squeezed together but Im not sure how, I have tried clamping it to get a better connection but it's still leaking
Is this a common prob and how can I fix do I need a special tool?
Thanks
Trev
Old Aug 1, 2006 | 09:21 PM
Trev's Avatar
Trev
anyone?
Trev
Old Aug 1, 2006 | 09:28 PM
James's Avatar
James
Can't picture it in my head but i'm guessing it's just a breather pipe that runs from the cam cover to the crank case? inwhich case it sounds like the pipe is probably blocked and sucked itself in kinda thing, take the pipe off and clean it out, if it doesn't return to shape then replace it.
Shouldn't need special tools as such although the hos clips will be tricky unless you have some grips/pliars handy.
Old Aug 1, 2006 | 09:30 PM
radiant red's Avatar
radiant red
oil pressure switch
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
CossieRich
30
Sep 8, 2015 10:08 PM
Russ Hill
Aug 31, 2015 06:44 PM
nick8saff
Aug 16, 2015 05:35 PM
