EFi relays
Jul 14, 2006 | 06:55 PM
EFi relays
Im starting my efi conversion tomorrow just need to make sure that the fuel and ecu relays are the same and are they yellow ones about an inch square?
Jul 14, 2006 | 07:34 PM
Jul 14, 2006 | 10:31 PM
this is what you want
dont use the ones that are in the s2 original fuse box as the circuits are different as i found out 2day
Jul 14, 2006 | 10:46 PM
Ok thanks looks like the ones I have.
Jul 14, 2006 | 11:22 PM
Quote:
the ecu relay is red
Jul 15, 2006 | 05:35 PM
If the ecu relay is red is it the same size as the yellow one pictured above or is it the taller one?
Jul 15, 2006 | 05:42 PM
yep same size
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
