regular fuel hose? (simple question)
hi all..
just found out that the fuelhose between the fuelpressure-regulator and the fuelrail has some cracks in the outside layer..
can someone confirm that this is just regular fuel hose (8 or 10mm?)?
just to be sure, so I can get myself a new piece of hose and replace it..
thanks
(it's for a saff cos by the way)
thanks
Thats the one that starts most fires!
Its -6 mate. I would replace the feed and return as well while you are there. You local motor factors will have the correct stuff
Ian.
Ian.
JK12
33
Apr 26, 2021 12:09 PM
