chip on s2 erst ecu
take it u dont know what its 4 then,it was also written on the chip aswell in pen,im new with turbo motors so any idea on what it could b 4 would b a great help,i dont want 2 go and buy a new chip 4 the car if i dont need 2,take the piss all u want but i dont care
Sounds like a stranded chip to me, is it soldered to the circuit board
As most after market chips are unplug able, look at the photo in an earlier post
Steve
Steve
That metal clip over the chip can be removed (carefully, from the reverse) to see if the chip itself has a tuner sticker on it. ECU's are static sensitive too don't forget.
Uprated chips are sometimes soldered directly to the board, but most tuners would solder back in a socket thesedays (same amount of work, less risk, and easier for future changes)
chip has a little white sticker on it with lcs3 9205 written on it and som1 has written it on the actual chip aswell,deffinatly looks like its plugged in,its a motorola chip if thats any help
does the chip in the pic look like its a plug in 1 do u think,mine looks just like that,not directly soldered 2 the board,any chance sum1 could hav plugged a standard chip back in
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mc5506
Oct 5, 2015 09:57 PM
