rst idle problem.
Old Jul 12, 2006 | 05:00 PM
Miketweed's Avatar
Miketweed
Default rst idle problem.
i cant get my rst 2 idle. i have just put a new turbo on and it doesnt idle. it also gets very hot very quickly. plz plz plz can somebody help me as its been off the road for 2 months now!
Old Jul 12, 2006 | 05:27 PM
SafeChav's Avatar
SafeChav
If it won't idle you must have an air leak.
If it won't idle how do you now its getting hot very quickly?
Old Jul 13, 2006 | 05:29 PM
Miketweed's Avatar
Miketweed
if i keep my foot on the accelerator it will run. as soon as i take it off it dies, ive tried playing with the idle control but it dosnt make a diffence..
Old Jul 13, 2006 | 05:41 PM
SafeChav's Avatar
SafeChav
Presumably an MFI RST? If so you clearly have an air leak.......also have you got a dump valve?
Old Jul 29, 2006 | 02:29 PM
neds2rst's Avatar
neds2rst
well mate you dont mention if its the turbo housing itself thats getting hot because i had something simmilar on my first engine i put in if it is check ignition timing at dizzy cap mabe needs advanced you dont mention how much boost mines used to glow red in very short drive though a cant remember exactly but a think turning it back towards car is advance and forward retard but double check first but if this is the case usally it would pink on boost
Old Jul 29, 2006 | 07:44 PM
antony215's Avatar
antony215
Escort Rs Turbo
As SafeChav say's may be an air leak check all the boost hose's are on tight and the dip stick is in properly.
Old Jul 29, 2006 | 08:45 PM
HORNETS7's Avatar
HORNETS7
back to basics here was it ok before u changed the turbo?
if so the only pipes u will have touched is the boost pipes so make sure they are all seated correctly and tight!
A.t.p
Oct 23, 2015 07:54 PM
Chas
Oct 5, 2015 07:13 PM
fordrallycar
Sep 30, 2015 07:57 PM
Billy_RS
Sep 13, 2015 04:17 PM
