gear box fluid
Jul 12, 2006 | 04:42 PM
gear box fluid
can any mtf be used for my s2? when filling up shall i just keep adding till it pisses out? is there a seperate drain plug?
Jul 12, 2006 | 05:04 PM
mtf? I think you are meant to use 80w semi synthetic gearbox oil. And also im fairly sure the level should 5 about 5mm below the filling hole
Jul 12, 2006 | 05:11 PM
A quality fully synthetic oil is what you want in an RST box. iirc CTS use Millers
DHMC
Ford Fiesta
Sep 30, 2015 07:15 PM
`spotty
Sep 25, 2015 11:41 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
cossirob
Sep 16, 2015 07:39 PM
