Standard Compression....
Whats its rated to BHP wise?
If you had say Firged pistons, and a decent set of steel rods, along with decent management, head etc would you get good figures?
Or would the std comp piss you about, then needing to lower it ?
If you do things properly, then about 220bhp.. If you don't do things properly, then the sky is your limit (well until the turbine wheel exits via the exhaust or you lose a piston)..
Std compression won't be a problem at all, even for very big power if it's mapped for it. I used to run upto 23psi on KE on 8.5:1, no bother.
But, if yoiu are putting in forged pistons, then they will no doubt need to be skimmed, so may as well drop it to a little under 8 if your planning loadsa boost
When you say 8.5:1 do you imply the static compression ratio or is it the dynamic compression ratio?
I've been trying to find some pistons for my 1.9 (I live in Canada) and found someone who can get a set Mahle's. I was hoping to get a set of standard RST's over sized to 82.5mm. It's hard to do when you don't know if the standard RST's extend past the block.
yes, all ratio's are referred to as static. 8.3 is std, 8.5 was due to a skimmed head. Std RST mahle's do come up over the deck - 1.5mm i think is around std, would have to check. You won't get std pistons at 82.5 (
I've been trying to find some pistons for my 1.9 (I live in Canada) and found someone who can get a set Mahle's. I was hoping to get a set of standard RST's over sized to 82.5mm. It's hard to do when you don't know if the standard RST's extend past the blok.
Originally Posted by reality
Your 1.9 also has a different head to our 1.9.. (well, our 1.9 is a CVH head on your 1.9 block.. just to confuse things)
can u not get a 1600 block over there? Also, for the price of Mahle's over here (250-300 pounds) i'm sure you could get forged pistons made by someone like JE or ROSS from the US just as cheap, and they would be even stronger.
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
