What's this thing EFi Conversion?
Jul 11, 2006 | 06:49 PM
Jul 11, 2006 | 07:56 PM
That is a moisture trap type effort, to help prevent fuel and oil etc getting into the MAP sensor
Jul 11, 2006 | 08:24 PM
It'a also a damper to clean the pulsing pressure signal.
Jul 11, 2006 | 10:38 PM
some sort of one way valve
Jul 12, 2006 | 08:58 AM
Quote:
NEVER!! lol why would you want a one way valve connected in series with the MAP sensor
Jul 12, 2006 | 01:05 PM
Thanks for the replies. Its nice to know what goes where and why.
Jul 12, 2006 | 04:31 PM
BTW it shouldn't be coming off there as that part is blanked off usually
That's where people usually take the feed from for a usefull boost guage or a not even vaguely usefull dump valve
Jul 12, 2006 | 04:40 PM
I'll have a look at my mates Fiesta RST and see where its supposed to go.
Dave
Jul 12, 2006 | 04:57 PM
It usually comes off the opposite side of the inlet manifold, but what Oranoco didn't mention (tut tut you're slacking boy
) it doesn't matter as long as its giving the MAP sensor a vacuum supply from directly within the inlet manifold
Jul 12, 2006 | 05:00 PM
Cool. While your on. Is 90 degress BTDC the correct position for the missing tooth on my trigger wheel?
Got most of my stuff together now ready for the conversion.
Jul 12, 2006 | 05:01 PM
Indeed it is
Jul 12, 2006 | 05:03 PM
Arrrrrrre vely good. Next stage is the wiring. Which should be fun.
Jul 12, 2006 | 05:05 PM
Jul 12, 2006 | 05:10 PM
Didn't want to mention it I was just being a picky old fart
Jul 12, 2006 | 05:13 PM
Alright easy grandad...........don't want you having a heart attack
Jul 12, 2006 | 05:14 PM
Jul 12, 2006 | 05:15 PM
Sorry did you say something my hearing aid is switched off
IainRS1700T
Sep 25, 2015 06:44 AM
liamT74
Sep 23, 2015 10:24 PM
davidfordrs
Sep 21, 2015 04:23 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
