Fitting oil pressure gauge
Old Aug 13, 2004 | 05:21 PM
B11GNS's Avatar
B11GNS
Default Fitting oil pressure gauge
i am trying to fit a capillary o/p gauge, on the end of the line (engine side) i have a 1/8bsp fitting and i was going to fit it where the pressure switch is via a t-piece but found when i removed the switch that it was a much larger thread. Do i need to get a different adaptor or should i fit it somewhere else?
Old Aug 13, 2004 | 05:31 PM
SteveB's Avatar
SteveB
you need an adaptor
Old Aug 13, 2004 | 05:33 PM
B11GNS's Avatar
B11GNS
Next question then is where can i get one from, i got my current bits from burton, will i be able to get one from there?
Old Aug 13, 2004 | 06:15 PM
tkrath's Avatar
tkrath
I bought a T-piece from SCC Performance but i did not fit mine (it was to big). Therefore I had a local company to make another one for me which fits fine.
/Thomas Krath
Old Aug 13, 2004 | 07:27 PM
Micky's Avatar
Micky
Burtons should have an adapter,I got mine in Demon Tweeks.Regards Micky
Old Aug 13, 2004 | 07:33 PM
B11GNS's Avatar
B11GNS
Cheers, will contact burton tomorrow
Phil's Avatar
Phil
Jeebus
I got one from Demon Tweeks as well..
Old Aug 13, 2004 | 07:35 PM
B11GNS's Avatar
B11GNS
And if i have no luck i'll contact demon tweeks
Old Aug 13, 2004 | 07:37 PM
B11GNS's Avatar
B11GNS
Have you got the part number?
Old Aug 13, 2004 | 08:11 PM
WutangRS's Avatar
WutangRS
try here loads of different fittings and hoses
http://www.h-e-l.co.uk/
RUBY123
Oct 22, 2023 12:04 PM
Chas
Sep 21, 2015 08:57 PM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
Perfmr2
Aug 6, 2015 07:30 AM
