cosworth boost problem
Old Jul 9, 2006 | 05:09 PM
daversturbo's Avatar
daversturbo
Default cosworth boost problem
bourght a cosworth a couple of weeks ago dark greens 3 bar map but was only boosting at 10 psi went to turn it up wound the rod right in and it only turned it up to 13psi and doesn't seem to boost properly tried my brothers actuator that was boosting 22psi but when i put it on mine it would only boost at 6 psi i have checked boost pipes and taken dumpvalve off but it is still the samecould it possibly be the vacum pipes as they have been changed to blue ones and i had a problem like this on my frst
Old Jul 9, 2006 | 06:35 PM
jon@work's Avatar
jon@work
wouldn't the fact the your brothers actuator boosted up to 22psi suggest to you that your actuator has seen better days and it may be time to replace it ?
Old Jul 10, 2006 | 05:01 AM
daversturbo
sorted
Old Jul 10, 2006 | 05:14 PM
b6mgb's Avatar
b6mgb
I assume that your brothers actuator boosted to 22 on his car but only 6 on yours.What sorted out the problem?
Old Jul 10, 2006 | 05:16 PM
b6mgb's Avatar
b6mgb
Old Jul 10, 2006 | 05:58 PM
daversturbo
the proper vacum pipes from amal valve to turbo and actuator
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
