caliper choices ??
what choices are there on the market at the min for calipers ?? for exaple could i buy focus rs calipers and use them ??? what disces and mounting brackets would i use and where would i get them ?
or mits evo calipers i know of a few using where did u get discs and mounting brackets ??
Bought FOCUS RS BREMBO,S for mine.You will needs the discs and specialy made brackets aswell.Also the minimimum wheel size using these is 17 inch.
Not cheap though.Your looking at about £600 for the lot(secondhand).
Try E-BAY FOR THE CALIPERS & DISCS.about £450
ZOO MOTORSPORT for the adapter brackets.£85
UPRATED BRAKE LINES & BRAKE FLUID.£100.
Originally Posted by scottbrown
are the fiat coupe brembos exactely the same as the focus ones? there is a set on flea bay for buy now £180. which seems a bargain
No they are different.FIAT are radial mounted and FOCUS RS BREMBO,S are side mounted,but you can get brackets to mount both of these.
