how to undo speedo cable from back of clocks!!
Old Jul 9, 2006 | 09:43 AM
cos330's Avatar
cos330
Default how to undo speedo cable from back of clocks!!
how do you undo the speedo cable from the back of the clocks?
Old Jul 9, 2006 | 10:35 AM
SafeChav's Avatar
SafeChav
What car
Old Jul 9, 2006 | 10:45 AM
cos330's Avatar
cos330
Default cossie 2wd
cossie 2wd. got clock out but cable won't come off..
Old Jul 9, 2006 | 10:59 AM
SafeChav's Avatar
SafeChav
Theres like a white plastic ring which is offset, you have to push the white plastic bit to unlock it and then pull, it might be tight.......
Old Jul 20, 2006 | 06:29 AM
If you feel around the outside of the white plastic ring you will feel two opposite positioned serated parts, squeeze here and it will distort to release the cable "bit" that sticks in the hole top hold it in.
Much the same as SAFECHAV says I just find it easier to feel for the serated bits on the ring.
3drRich
Sep 13, 2015 07:32 PM
whizzisat114
Sep 1, 2015 02:19 PM
Sultzi
12
Aug 16, 2015 01:08 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
