escort coss help
Old Jul 8, 2006 | 09:39 PM
paul398's Avatar
paul398
Default escort coss help
i have a bad vibation when i accelarate if i back off it stops could this be the gbox bushes
Old Jul 8, 2006 | 09:56 PM
kjc300's Avatar
kjc300
check the exhaust downpipe isn't touching the chassis.....
Also, check your engine mounts aren't knackered!!
Old Jul 9, 2006 | 10:35 PM
silky16v's Avatar
silky16v
Get on That!
check all engine & gearbox mounts also check the UJ's in your front prop shaft and also if the exhaust is sat to close to the chassis or front prop shaft
Old Jul 20, 2006 | 07:55 PM
paul398's Avatar
paul398
cheers8
Old Jul 21, 2006 | 12:29 AM
sailorbob's Avatar
sailorbob
I'd check the cv joints first, most likely to wear and cause a vibration under acceleration, then move onto the suggestions above.
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
