1.8CVH?
Old Jul 8, 2006 | 05:58 PM
Billy_RS's Avatar
Billy_RS
Default 1.8CVH?
Is it possible to use the bottom end of a sierra 1.8 cvh and bolt my rst turbo head to it?
is it worth the hassle?
cheers lads
Old Jul 8, 2006 | 06:58 PM
turbo.jon's Avatar
turbo.jon
not worth it mate and dont think there very reliable as i asked same thing ages ago and its what i got told
Old Jul 8, 2006 | 07:20 PM
TURBO BOI's Avatar
TURBO BOI
ive heard only bad things bout the 1.9 jobbys, never heard bad things bout the 1.8's, ferriday engineering do the 1.8 bottom ends
Old Jul 8, 2006 | 09:18 PM
gambit's Avatar
gambit
Default 1.8
well people will tell you bad things bout everything but there are alot of factors to bare in mind. As above ferriday do a very good package and regarding the 1.9 cvh they can be very reliable it just depends whos built em. But yes you can bolt your head up to one, and ferriday uses zetec pistons in his conversion by the way.
Old Jul 8, 2006 | 09:40 PM
SafeChav's Avatar
SafeChav
From what i've learn't the 1.8 bottom end is meant to be shit turbo'd because of the stroke and so forth.....
I had the same brain storming session you did
Old Jul 9, 2006 | 12:44 AM
James's Avatar
James
Thing i've found previously whenever the 1.8cvh is mentioned everyone says how rubbish it is but no-one has actually done it for themselves..
Old Jul 9, 2006 | 07:33 AM
ian r's Avatar
ian r
iam running a ferriday conversion on mine 4 years ago no problems loads of torque but i only run 15psi
Old Jul 9, 2006 | 08:36 AM
addiction's Avatar
addiction
i have an Interpro 1.8 conversion and after 3 years its been spot on. 230bhp and 252 lb of torque at 15 psi. ultra reliable too
Old Jul 9, 2006 | 10:17 AM
Billy_RS's Avatar
Billy_RS
if i was to try it, could someone list the parts id need to do it?
thanks
Old Jul 9, 2006 | 01:15 PM
Taylor's Avatar
Taylor
Would speak to Ferriday mate,very very helpfull they are!
Old Jul 9, 2006 | 07:46 PM
gambit's Avatar
gambit
Default 1.8 cvh
speak to ferriday
Old Jul 10, 2006 | 05:01 PM
rugged rick's Avatar
rugged rick
a young lad had one in his escort cabriolet a couple of years back, 1.8 from the sierra and it run like a bag of shit,he had no end of problems with it it used to go up the road popping and banging and misfiring.he then scrapped it and went on to do a 2.0 zvh conversion,so from what ive seen id give it a wide berth.
HTH
regards rick e
Old Jul 10, 2006 | 06:07 PM
addiction's Avatar
addiction
if it's done properly then you will have no problems.like i said mine has been running for 3 years and it has NEVER missed a beat!! and i do at least 4 track days a year in it.
Old Jul 11, 2006 | 09:28 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Havent read the topic only the title..
The 1800cvh has the same rods and crank that is used by WELL KNOW ENGINE builders, for their 1900cvh engines
The rods and crank fail with your Grandad driving so god help the poor engine if Turbo'd
Declan Gallen
Feb 14, 2013 01:14 PM
barrychambers30
Aug 26, 2011 06:39 PM
Paul
Sep 21, 2005 08:50 PM
