Help - Accralite Pistons
Old Aug 13, 2004 | 12:47 PM
Nath-25/09's Avatar
Nath-25/09
Default Help - Accralite Pistons
Are the above pistons from Burton Power for the 2.1 Zetec E turbo conversion low comp??
beer for help
Ta
Nath
Old Aug 13, 2004 | 12:59 PM
Nath-25/09's Avatar
Nath-25/09
no worries all sorted.
How much too have them machined and where??
Old Aug 13, 2004 | 01:01 PM
zvhturbo's Avatar
zvhturbo
Burton will machine them to lower the compression even more for you.
Here are mine.
Old Aug 13, 2004 | 01:11 PM
Ryan's Avatar
Ryan
god damn ZVH your walls are a bit thin
Old Aug 13, 2004 | 01:14 PM
Jim Galbally's Avatar
Jim Galbally
jesus christ those ring bits touch are they supposed to do that ?
Old Aug 13, 2004 | 01:15 PM
CraigN's Avatar
CraigN
arent accrilite pistons meant to be a bit wank ????
Arias are the piston of choice by Mr Howell and or Cosworth racing pistons
zvhturbo's Avatar
zvhturbo
Its called a wire rung block
Old Aug 13, 2004 | 01:16 PM
Nath-25/09's Avatar
Nath-25/09
cheers matey, how much did it cost ya?
How much are calbra pistons!
I rang burton and they said the crowns are unfinnished which is fine, but he never said anything about them finnishing it off!! grumpy git he was!!
Cheers fellas
Old Aug 13, 2004 | 01:18 PM
zvhturbo's Avatar
zvhturbo
Unfinished just means totally flat.
If you want to lower the compression to run more boost you can have them dished like mine are.
Cost was about £160 each (that was 3 years ago)
Old Aug 13, 2004 | 01:19 PM
zvhturbo's Avatar
zvhturbo
Only opened up 1mm from standard.
Old Aug 13, 2004 | 01:24 PM
Nath-25/09's Avatar
Nath-25/09
Cheers mate, just trying to work out whats the best way!!
what would you do?
Old Aug 13, 2004 | 01:29 PM
Ryan's Avatar
Ryan
bloody hell is that all, didnt realise they were that thin,
is a a 1.8 block or 2.0?
Old Aug 13, 2004 | 01:32 PM
Garage19's Avatar
Garage19
£640 to dish a set of pistons!!!!!
Bloody Hell!
A company like Arias or JE would have done you a set of made to spec dished pistons for less than that.
Old Aug 13, 2004 | 01:33 PM
zvhturbo's Avatar
zvhturbo
2.0
Old Aug 13, 2004 | 01:34 PM
zvhturbo's Avatar
zvhturbo
Bloody Hell!
£160 each was to buy the piston, have it machined and to have it fitted.
Old Aug 13, 2004 | 01:39 PM
Nath-25/09's Avatar
Nath-25/09
cheers guys - is this the best option?
Old Aug 13, 2004 | 01:48 PM
zvhturbo's Avatar
zvhturbo
Best speak to the people that are building your engine.
Its really what they feel works best or what you would prefer.
Personally i've had no problems with mine.
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
