s1 bonnet keeps opening
Old Jul 8, 2006 | 03:59 PM
turboben's Avatar
turboben
Default s1 bonnet keeps opening
hi every time i go over a bump in my s1 the bonnet keeps popping up as if i have pulled the bonnet release how can i stop this as i dont want it popping up at 60mph and coming off the latch
cheers ben
Old Jul 8, 2006 | 04:08 PM
gus's Avatar
gus
bonnet pins?
not too everyones taste but will stop flying up at speeds
or tie it down from the inside
Old Jul 8, 2006 | 04:29 PM
dave_y's Avatar
dave_y
how do you tie it down from the inside? where do you attatch it?
Old Jul 8, 2006 | 04:46 PM
turboben's Avatar
turboben
i dont really want to use bonnet pins as it means drilling a genuine bonnet and changes the apperance
but it looks like i might have to go tohe bonnet pin route
what colur pins is everyone using on there s1
Old Jul 8, 2006 | 05:17 PM
gus's Avatar
gus
tie a bit of wire to inside of bonnet skin with a d bold or carabena (sp) on the end, clip it to arb or anything solid at the bottom of car
not pretty but it will work
Old Jul 8, 2006 | 07:29 PM
turboben's Avatar
turboben
what colour pins are everyone using
Old Jul 8, 2006 | 07:40 PM
andre_k's Avatar
andre_k
ginger
Old Jul 8, 2006 | 07:48 PM
scraggyrst's Avatar
scraggyrst
i heard people make tiny straps that are connected to the bonet and held to bottom of the car or buy whole new catch and cable
Old Jul 8, 2006 | 08:21 PM
SafeChav's Avatar
SafeChav
Its probably the adjustment of the catch, there are actually a few adjustments you can do it.
Give it all a once over how many people do you know that look after the bonnet catch and keep it in good order....
Old Jul 8, 2006 | 08:59 PM
turboben's Avatar
turboben
i have had a little look over it but i cant see how too adjust it
Old Jul 8, 2006 | 09:34 PM
SafeChav's Avatar
SafeChav
The plate in the slam panel will have very minimal adjustment with the screws loose, and you will also be able to adjust the positioning on the striker where it bolts to the bonnet, and you can also adjust the tension of the spring on the striker.
Have a look at the catch in the slam panel you may find its worn and thats why, but you shouldn't need to fit any other means a standard catch when working properly is very good.
Mine hasn't flown up on the rare times ive taken it round to its max of 130mph (touch wood now ive jinxed it )
Old Jul 8, 2006 | 10:40 PM
nigel b's Avatar
nigel b
the only way to adjust the bonnet height is by screwing the springy catch on the bonnet
alot of pattern bonnets lift at hight speed as the bonnet skin comes away from the bracing where it is bonded
mine seems to be ok but ive seen others that are bad
Old Jul 9, 2006 | 10:02 AM
turboben's Avatar
turboben
i think i may have to get some bonnet pins just in case has anyone got any pics of these fitted to there s1 would be great
cheers ben
Old Jul 9, 2006 | 10:13 AM
SafeChav's Avatar
SafeChav
Seriously don't put the bonnet pins on it will look shocking
If you are that worried why not buy a new catch and striker as someone has already suggested, could be a good opportunity to add a bling chrome one
Old Jul 9, 2006 | 03:51 PM
S1 JOHN's Avatar
S1 JOHN
dont do it not bonnet pins
try greasing up the catch some times they stick and the spring forces the bonnet open mine did the exact same thing the other day
hope this helps if it dosnt dont fit bonnet pins change everything before butchering the bonnet
Old Jul 9, 2006 | 04:45 PM
mercury grey minter's Avatar
mercury grey minter
ginger
Thougt it was YELLOW
sorry. Just buy new chrome ones and problem sorted
Bonnet pins are very GAY
Also,get a new bonnet release cable asthis could be sticking/kinked ,holding the catch half open all the time.
Old Jul 9, 2006 | 07:52 PM
RSTG65TOM's Avatar
RSTG65TOM
mine did used to do it...its because the bonnet cable was to tight on the catch, so all i did was slacken it off a bit
Old Jul 9, 2006 | 08:19 PM
turboben's Avatar
turboben
well for some reason it hasnt popped up at all today it only seems to do it every now and then, weird
and you will all be glad i have decided against bonnet pins i could not bring myself round to drilling the bonnet
but i have also been looking on ebay and on the net and i cant find a bonnet latch any where anyone got any ideas where i could get one from
Old Jul 9, 2006 | 08:34 PM
rs nutta's Avatar
rs nutta
theres loads of them on ebay, or ask somone thats breaking one if they have a good condition one
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
gingeRS
17
Oct 2, 2015 09:42 AM
